Juho
Posted: Sun Sep 29, 2019 12:30 am Post subject: 1 stud build |
Started a new thread for my build because ive got no clue what im doing with it atm. Got itbs, bike carbs, supercharger laying around atm.
When i was taking intake manifold studs (which are in cylinder head) off i broke 1 of the studs so now i have to get the head off, get it machined and replace the hg and put this all s*** together. Thats why im calling it 1 stud build because all of this is because of it.
This is my first time ever taking a really anything bigger off than waterpump from my 924 because its been very "reliable" track car.
Tried taking off the exhaust before pulling the head but my knuckles already said no to that. And lost my 13mm somewhere in narnia (rolled down the engine mount).
Ive already taken some coolant lines off, everything related to intake and distributor. Which timing i think i f**** it because the engine isnt tdc atm and i took it off and spun gears. I havent taken the timing belt off because the engine isnt tdc atm.
Ill be posting pictures of this later today, need to tidy up the garage more to pull the head off (need table space). Also i hope ill be finding my haynes manual there. |
Juho
Posted: Sun Sep 29, 2019 11:35 pm Post subject: |
Fun times |
Juho
Posted: Tue Oct 01, 2019 4:05 pm Post subject: |
| manifold removed from rest of the exhaust. Just got one annoying 7mm nut behind the head and its ready to come off.... hopefully today |
Juho
Posted: Wed Oct 02, 2019 4:44 am Post subject: |
| Well just did a 45 minute trip for wrong size bolt, anyone knows the size of the xzn head bolt? |
safe
Posted: Wed Oct 02, 2019 4:50 pm Post subject: |
| Juho wrote: | | Well just did a 45 minute trip for wrong size bolt, anyone knows the size of the xzn head bolt? |
I just try one socket after the other until one fit... Buy a set.  |
Juho
Posted: Thu Oct 03, 2019 5:45 am Post subject: |
This was scary but yeh. Job done but not well  |
safe
Posted: Thu Oct 03, 2019 6:19 pm Post subject: |
Step no1 done!
Keep track of TDC on the crank, cam and distributor and it vill go together smoother if you are unsure. |
Juho
Posted: Wed Oct 09, 2019 3:47 am Post subject: |
Picked up the head from the shop today . Should i do something to the surface rust on water jackets? |
safe
Posted: Wed Oct 09, 2019 4:03 am Post subject: |
| Juho wrote: |
Na, but assume the shop stuffed as much metal chips as possible down every orifice as clean accordingly.... |
Juho
Posted: Wed Oct 09, 2019 4:46 am Post subject: |
| safe wrote: | | Na, but assume the shop stuffed as much metal chips as possible down every orifice as clean accordingly.... |
Im going to buy a compressor tomorrow to clean everything before i put them back together. |
Posted: Wed Oct 09, 2019 6:22 pm Post subject: |
Surely the machine shop would deep clean/put in a parts washer after working on the head before rebuilding?????? _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
safe
Posted: Wed Oct 09, 2019 6:57 pm Post subject: |
| Carrera RSR wrote: | | Surely the machine shop would deep clean/put in a parts washer after working on the head before rebuilding?????? |
Doesn't look like the head has been dissembled or cleaned, based on the crud still on the head and carbon on most valves.
You can fly cut it without removing the valves. |
Juho
Posted: Thu Oct 10, 2019 3:08 am Post subject: |
| I only took off the camshaft, just got the broken studs drilled out and head decked |
TJC
Joined: 04 Apr 2010 Posts: 828 Location: Northwestern-ish Arizona, USA
Posted: Fri Oct 11, 2019 12:59 am Post subject: |
Just out of curiosity why didn't the machine shop freshen up the head while you had it in there? Have you have a valve job, guide check, seals, etc. done very recently? _________________ '95 BMW 318i/5 ..."Pearl"
'04 BMW X3..."Xander"
Still on the Prowl!
www.ttrs1.com |
Juho
Posted: Fri Oct 11, 2019 3:38 am Post subject: |
| I didn't have them done, but i think last owner did because he put the aftermarket camshaft in and replaced all the gaskets because they all seemed pretty fresh. I didn't get anything else done to the head because I am disassembling whole engine after next summer's track days and i might be getting turbo cylinder head and forged internals. |
