Porsche 924 Racecar Build Thread (AAN Conversion)
Goto page Previous  1, 2, 3, ... 10, 11, 12  Next
jacobroufa
PostPosted: Mon Jun 24, 2019 12:39 pm    Post subject: Reply with quote
Dang this is inspiring! Thanks for sharing!
1980 Porsche 931
1981 Porsche 924 Weissach
Stophosjr
PostPosted: Mon Jun 24, 2019 12:52 pm    Post subject: Reply with quote
Holy shit. I want it. No joke, if you ever want to move on, contact me.
1987 924 gts outlaw
Qik Nip
PostPosted: Tue Jun 25, 2019 5:46 am    Post subject: Reply with quote
I am duly impressed. And I thought I'd created the world's costliest 924!
'79 NA 924 Land Speed Car
Bonneville G/CPRO record @ 149.825MPH
Arkansas Mile G/CPRO record @ 138.0 MPH
Great Lakes SCCA SM points champion '09,'10,'11
MikeJinCO
PostPosted: Tue Jun 25, 2019 12:36 pm    Post subject: Reply with quote
Absolutely amazing. Your parts fabrication and engineering are top notch and you have many unique and cost saving solutions. I really liked your approach for the strut tower brace, simple and cheap. Also your lower caster block brace is quite unique and an often overlooked but quite necessary part. I do wonder why you went with AAN over using the VW 1.8T.
Mike
'67 MG Midget Dp
PostPosted: Tue Jun 25, 2019 5:02 pm    Post subject: Reply with quote
The 5 pot sound? Potential 400hp?
PostPosted: Tue Jun 25, 2019 5:17 pm    Post subject: Reply with quote
5 pot sound is the best.
I have a 5 cyl diesel and even that one sounds great.
Wish the 924 came with a 5cyl from the start.
MikeJinCO
PostPosted: Wed Jun 26, 2019 2:55 am    Post subject: Reply with quote
I was not running down the I5, I had one of the early Audi Coupe Gt's(wish I still had it). I was best driving car I ever had. I didn't realize the equipment available for that motor until I looked up 034 motorsports. I wish we had parts like that available. Also a reasonably reliable 400hp in that car would be amazing.
Mike
'67 MG Midget Dp
Britain
PostPosted: Thu Jun 27, 2019 2:35 am    Post subject: Reply with quote
There were a couple of motivations to go with the 5-cyl.
1. The AAN engine bolted up to the 931 bellhousing and didn't require any adapter plates or anything to make it work.
2. We wanted to go with a slightly bigger displacement of the 2.2L 5-cyl so it wouldn't be as stressed as a high-strung 2.0L 4-cyl.
3. The 5-cyl is freaking cool and looks like it is supposed to go there.
-Britain
PostPosted: Thu Jun 27, 2019 3:45 am    Post subject: Reply with quote
Naaa, the in-line fives back then were heavy boat anchors. We had an early audi 80, the engine were gutless and heavy, i rather have the 2.0
Britain
PostPosted: Thu Jun 27, 2019 3:53 am    Post subject: Reply with quote
Ah...the AAN is 2.2L, 4valves/cylinder, awesomeness.
PostPosted: Thu Jun 27, 2019 4:51 am    Post subject: Reply with quote
Aan is a different animal, Mid 70s in-line fives were less awesome i can assure you fives sound cool and are fairly compact, though the gas exchange is a mess they can work really well. Definitely a much better use of the engine than having in sitting in a front heavy audi
A couple of years ago they were super common, especially as drag cars over here in audi s2s etc.
Britain
PostPosted: Tue Jul 09, 2019 4:22 am    Post subject: Reply with quote
Well...if you do this long enough eventually you are going to wreck your car.
We had an incident at the race this past weekend that resulted in contact with the wall down the front straight of PIR at abut 60mph. The data showed that the car hit the wall at about a 120deg angle with -1G of LongAcc and -2.5G of LatAcc. Not the hardest hit in the world, but enough the tear up the front end of the car.
Started tearing it apart last night and I think that their is minimal frame damage and it can be repaired. My plan is to get the suspension damage repaired to get the car rolling and then take it to the alignment shop to measure the chassis to make sure it is ok before repairing everything up front.
PostPosted: Tue Jul 09, 2019 5:49 am    Post subject: Reply with quote
That absolutely sucks having just repaired the rear and a fresh motor install!!
PostPosted: Tue Jul 09, 2019 6:23 am    Post subject: Reply with quote
Sorry to see this.
KDJones2000
PostPosted: Tue Jul 09, 2019 8:21 am    Post subject: Reply with quote
Here's hoping that it is repairable...
1987 924S SPEC car
Team Toofah Racing
1988 944 Turbo S
Page 2 of 12
