931 S1 Boost retard
Raize
PostPosted: Fri May 31, 2019 4:57 am    Post subject: 931 S1 Boost retard Reply with quote
Does anyone have the curve for a RoW S1 931 ignitions vacuum/boost advance/retard?
Failing that, does anyone know the maximum amount of degrees of boost retard that is applied, and how many PSI of boost it takes to reach that maximum value?
PostPosted: Fri May 31, 2019 5:54 am    Post subject: Reply with quote
http://924board.org/viewtopic.php?t=37214
80 Turbo - Slightly Modified
Raize
PostPosted: Fri May 31, 2019 11:03 pm    Post subject: Reply with quote
There's a curve for USA 931 but not for RoW. Not sure it's a safe assumption that they have the same curve given that the USA model had only 140hp and the RoW 170hp.
Not sure it's really relevant anyway, I was looking at swapping a 931 vacuum can onto a 924 distributor to get boost retard for a supercharger but they're horribly expensive and/or NLA. There doesn't seem to be a cheap option for this.
I wonder if the vacuum can is adjustable in any way. If I could add 5-10 degrees more vacuum advance, pull 5-10 degrees from the static timing, and use manifold instead of ported vacuum to keep a decent idle then it would achieve the right effect.
With the prices of 924 bits these days I don't really want to start drilling into vacuum cans though. The days of this being a cheap car to get parts for seem to be gone.
PostPosted: Sat Jun 01, 2019 4:10 am    Post subject: Reply with quote
Aldon Automotive can make modify a distributor to any advance/retard curve within reason. If not going stand-alone ecu route you could take a look at 123ignition dizzies. Either their stock bodies or the Mittelmotor option which are both programable with boost input.
