Main crankshaft bearings still an issue - NLA?
AlexJ
PostPosted: Thu Mar 07, 2019 6:02 am    Post subject: Main crankshaft bearings still an issue - NLA? Reply with quote
Hi all,
I have noticed through this board reading that over the times to get a main bearing crankshaft set has been difficult (STD) or almost impossible.
Is this issue sorted?
Are they available now?
If anyone knows any source, please inform.
Thanks in advance for any help.
AlexJ
PostPosted: Thu Mar 07, 2019 6:10 am    Post subject: Reply with quote
I forgot to say that the car in this case is a 924 Turbo from 81.
I have read so,ethereal that there are two bearing versions for this car.
Internal diameter 60 mm and 64mm.
Earlier cars have 60 mm crank diameter and latter cars have 64mm.
My car’s crankcase has 64 mm crank diameter...
Can anyone confirm this information?
I believe the bearings for the 64 mm are easier to find?
PostPosted: Thu Mar 07, 2019 8:51 am    Post subject: Reply with quote
Just measured a couple cranks, turbo and NA. Both 64mm mains. I believe only the 76/77 early cars had the 60 mm crank. Either way, first turbos were later cranks (64 mm). BTW turbo and NA cranks are identical except for the location of the input shaft bearing. Totally swapable.
AlexJ
PostPosted: Thu Mar 07, 2019 10:05 am    Post subject: Reply with quote
Thanks for your explanation !
I have seen many adds at the ebay (glyco sets for example), but they are indicated for engines 85 - up... 2.5 engines and further...
Sorry my ignorance but, do these 2.5 engines have a different crank?
or.. is it the same block???!!
PostPosted: Thu Mar 07, 2019 10:24 am    Post subject: Reply with quote
Yes, the 2.5 924S motor is a Porsche motor from the 944, a completely different motor. I doubt there are any interchangeable parts. EBS Racing had the last known supply of 924 main bearings.
Mike
Goldwolf
PostPosted: Thu Mar 07, 2019 10:33 am    Post subject: Reply with quote
I need some, but engine guy can machine the crank and use the oversize, which are easier to get.
I called EBS about 10 days ago and they had a new run being checked for quality, then sending the order to make them. They said about month after the order they would have them.
I need check in on the progress.
1981 Weissach Edition #179
nickthompson
PostPosted: Thu Mar 07, 2019 11:31 am    Post subject: Reply with quote
They are available in Europe. One of the guys on the 924 owners group in Facebook posted a link to a place that had them.
Goldwolf
PostPosted: Thu Mar 07, 2019 1:35 pm    Post subject: Reply with quote
I could find only one link but it doesn't seem helpful. If you can find it please share.
AlexJ
PostPosted: Thu Mar 07, 2019 2:39 pm    Post subject: Reply with quote
Thanks for that!
I have been watching all their posts but couldn’t found it...
AlexJ
Alreadycontacted them... 8-12 weeks until they are done... can’t wait that long!
PostPosted: Thu Mar 07, 2019 7:52 pm    Post subject: Reply with quote
Limited availability via Karl/colonel @ 924ownersclub in UK or Mittelmotor in DE
PostPosted: Thu Mar 07, 2019 10:54 pm    Post subject: Reply with quote
That's wonderful news... I ought to hit them up and get on the list for some...
Kenodog
PostPosted: Fri Mar 08, 2019 3:57 am    Post subject: Reply with quote
I would wait the 8-10 weeks and get them from EBS. Mittlemotor prices are just zooming around the realm of insane.
Me
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
AlexJ
PostPosted: Fri Mar 08, 2019 11:27 pm    Post subject: Reply with quote
Thanks for that but I couldn’t find any of those names on the owners club web page.
Do you have any contact to these people?
Mike9311
PostPosted: Sat Mar 09, 2019 2:22 am    Post subject: Reply with quote
Ok, I am going to let out a tease...Been holding this one close to my chest for a while now
I have a solution in the works. A solution that should give us bearings for a long time with many size options
Sorry for being so vague but I want to make sure it goes as planned and is tested...I guess now I should accelerate this project too
the teaser pic. Top Left: OEM / Bottom Right: My solution (high quality source)
1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
1982 931 wana-be GTR race car
