I need some info on replacing the Thermo time switch
Johann
PostPosted: Fri Feb 01, 2019 4:33 am    Post subject: I need some info on replacing the Thermo time switch Reply with quote
I want to replace my thermo time switch. This is presenting me with two problems:
1) Where can I buy the correct switch?
I bought what I believed to be the correct switch but received this:
Part number: F026T03100
Will this work? I think there might not be enough room?
2) Can this be replaced with the motor in place?
gerben1986
PostPosted: Fri Feb 01, 2019 5:58 am    Post subject: Reply with quote
What is the correct number of the thermo time switch you need?
I can have a look if I have one laying around.
But this one won't fit, it will hit the firewall.
They can be replace with the engine in place I heard, but it will be a struggle…
Create as much room as possible (lifting the engine a little up, or push it forwards, remove cables and hoses etc.)
911SC - 1980
PostPosted: Fri Feb 01, 2019 6:49 am    Post subject: Reply with quote
It may hit the bell housing, not the firewall. May be easier to remove the housing than the TTS on its own. It will be tight and you won't get a spanner or socket on it.
Harm
PostPosted: Fri Feb 01, 2019 8:26 am    Post subject: Re: I need some info on replacing the Thermo time switch Reply with quote
IIRC Porsche ran a new batch in ~2016 that went into the classicshop, part number 928 605 101 02
On display in Canada: http://porscheaccessories.ca/classic/924/thermal-timer-switch/2267
Try the Porsche Parts Counter local to you with this info
Hardly.
Loosen gearbox and engine brackets. Slightly tilt the engine towards the drivers side and get your left arm in behind the engines head from the exhaust side/passengerside. Remove the Spark Distributor so you'll have a clear view down the back of the engines head. Hardest part is taking the metal clip of the connector …and getting it back on after replacing it.
Do it once, clean it all up and take your time.
Kind regards,
Harm.
PostPosted: Fri Feb 01, 2019 11:02 am    Post subject: Reply with quote
An alternative would be to install a momentary switch in the car. Think of it as serving the same function as an old fashioned choke or primer. When cold starting, push the button for a few seconds to activate the cold start valve while cranking. When hot starting don't push it.
Johann
PostPosted: Sat Feb 02, 2019 4:32 am    Post subject: Reply with quote
Thank you very much guys!
Looking at the trouble I will have to go through, I think I will just wait until I have to do the clutch to tackle this job. I can live with the cold start not working. I am chasing perfection here, but blipping the throttle for a couple of seconds is no punishment
I will also be sending the unit I received back and will enquire with Porsche for the correct part.
PostPosted: Sat Feb 02, 2019 5:18 am    Post subject: Reply with quote
Is the car a pain to start when cold? Mine starts on the button without the 5th injector.
Will be far easier to swap out with bell housing off when replacing the clutch for sure. You can unscrew it from below.
pierro
PostPosted: Sat Feb 02, 2019 11:42 pm    Post subject: Reply with quote
I've installed the longer one you showed in your photo and it's working fine, not touching anything (plenty room around it) and fonctioning properly.
The original shorter version is NLA, so this is the only proper alternative.
Porsche 924 1983restored
MG-Midget 1974 restored
Citroen 2CV 1986 restored
Rover Mini 1275 1992 restored
Mazda MX-5 1.8 for the fun
Toyota Lancruiser Prado daily driver
Merceds Benz W124 230E for the quality
Johann
PostPosted: Sun Feb 03, 2019 2:34 am    Post subject: Reply with quote
Not really, it starts fine if I drive it daily. When it has been standing for a week or so, it starts right away, but then sputters and dies, on the second attempt it starts better and the settles into a solid idle.
That’s good news Pierro! In that case I will hang on to it until I do the clutch change.
