Pc007
Posted: Sun May 06, 2018 6:37 pm Post subject: 1982 Porsche 924 turbo back to life |
Hi guys ! I’m from sunny Europe and Just got an 82 924 Turbo, being a Porsche fan, this is probably my favourite transaxle, very nimble car with more than enough power to have real fun!
So the car has been stoped for 10 years and previous owner had it running for w few months before selling the car, it drives as it should for a “10 year on the barn” car!
So I was thinking of going this route on immediate maintenance to the car:
- oil/ filter
- air filter
- gasoline filter
- water pump
- engine “chain”
- cooling fluid
- plugs
- fuel lines? Any one I should absolutely replace?
- suspension
- arms bushes
- engine mounts
- clutch/ flywheel
- bearings
- Ac charge
- new exhaust ( corroded)
- brakes/ fluid + restoration kit
So any thing I should also address in this “ back to life” project?
Also Can you guys give me some ideas for exhausts (“improve” a little the noise and performance) and also suspension, what’s the best choice for you guys?
Thanks!!
Posted: Mon May 07, 2018 1:51 am Post subject: |
Powerflex bushings do a lot, if you fit a larger diameter mufler at the end of the factory exhaust it will sound much richer. _________________ Supercharger and EFI kits
Joined: 29 Jul 2001 Posts: 9132 Location: Royal Oak, MI, USA
Posted: Mon May 07, 2018 3:17 am Post subject: |
Um... did I not see timing belt on that list??
I've been very happy with ride quality, performance, and durability of the Bilstein HD shocks on mine.
Welcome to the board! Where in Portugal are you? Have some family over there, Estoril and such... _________________ Vaughan Scott
Pc007
Posted: Mon May 07, 2018 5:31 am Post subject: |
Thanks for the feedback guys
Morghen, any brand and model for the exhaust?
924RACR, timing belt is what I indicated as “engine chain” for lack of English technical vocabulary... I’m based in beautiful Porto, 2hr drive from Estoril/ Lisbon! That’s very good to know that you have family in Portugal!!
About the Bilstein’s, is there a specific reference? Model? How can I distinguish the inserts in the front suspension? Is there a way to check it visually?
Thanks ! |
Posted: Mon May 07, 2018 6:11 am Post subject: |
I went with a custom stainless steel pipe welded on top of the factory mufler, the original piece was cut down from the box and a bigger diameter pipe was welded on. 80mm diameter if i remember correctly.
Sounded very very good for a 4cyl car. _________________ Supercharger and EFI kits
Posted: Mon May 07, 2018 9:16 pm Post subject: |
Exhaust = first lose the centre box. Weld in a new stainless section off the front pipe to the existing mid flange, no silencing. Then make a new stainless back box/silencer section of a size and sound you would like. Different sizes give a different noise/note.
I assume you have a stainless exhaust garage near you to do the work? Relatively easy to do for €200-400. Much better than buying an off the shelf option.
Will sound better and have less back pressure on the turbo so it will spool more easily. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Mon May 07, 2018 10:07 pm Post subject: |
Mmmm, maybe I need to line up a center box delete for my car... though IIRC it's the cat, which I'm not sure I'd want to cut out, just in case it's wanted later...
For the HD's, I think it's the only Bilstein available for the car? Bilsteins are green... Konis are yellow... but you probably don't have either... KYBs are white, OEM Boges maybe are blue? _________________ Vaughan Scott
Posted: Tue May 08, 2018 3:16 am Post subject: |
| 924RACR wrote: | | Mmmm, maybe I need to line up a center box delete for my car... though IIRC it's the cat, which I'm not sure I'd want to cut out, just in case it's wanted later... |
Make two mid sections off the front pipe. a straight through slip jointed mid section and modify the cat section to also slip joint the front pipe. Then you have an easy bolt/slip on alternative as and when required. Not need to touch the front or back section during the swap overs. Simples. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Tue May 08, 2018 3:29 am Post subject: |
Ah, yeah, good point... Durrr...  _________________ Vaughan Scott
