Fender/wing removal-its stuck
Gazc2
PostPosted: Sun Jan 14, 2018 2:42 am    Post subject: Fender/wing removal-its stuck Reply with quote
So I have removed all the top screws the three back ones ,the single one at the tip that joins to the badge panel and the majority of the wing is free and loose however the small flange that runs along the side of the headlight to the tip is proving reluctant.
any tips or advice appreciated
Gaz
PostPosted: Sun Jan 14, 2018 4:13 am    Post subject: Reply with quote
One in front, very tip of fender. Put finger in headlight bucket and you should feel it. Also 3 going to bottom valance.
Mike
Gazc2
PostPosted: Sun Jan 14, 2018 4:31 am    Post subject: Reply with quote
I got the one at the tip Mike, I have the valance and badge panel removed its just the small flange that runs along the headlight thats not budging.
cheers
Gary
PostPosted: Sun Jan 14, 2018 8:48 am    Post subject: Reply with quote
hard to type, arm in sling. Looked at mine that has fender off. A strip of adhesive. I'd warm it up then try to got a utility knife or such thru it, pry gently. Adhesive about 3mm thick. Don't remember a real problem with it.
luck
Mike
Gazc2
PostPosted: Sun Jan 14, 2018 7:29 pm    Post subject: Reply with quote
Thanks for your one arm typing efforts Mike somebody has suggested running a fishing line/wire to relase the mastic and this also checks for bolts although Im pretty sure I have all the bolts out wont get back to it untill next weekend however will post up my results
cheers
Gaz
PostPosted: Mon Jan 15, 2018 4:54 am    Post subject: Reply with quote
Old guitar strings are great for glues, that is how windshields get cut out also. make sure to wrap on a block of wood.
Mike
Gazc2
PostPosted: Sun Jan 28, 2018 10:34 pm    Post subject: Reply with quote
Just an update got the wing removed today it was nothibg other than the heavy underseal on the arch side of the wing holding it, gave it a few runs through with a stanley knife and it fell off so all good.
wing has a few issues though its been patched previously at the bottom and the front flange is also gone not sure whether to replace the wing or get the body shop to sort it out. would have liked to keep it original. also few bits of surface rust to sort out nothing major.
