fwood
Joined: 26 Apr 2010 Posts: 40 Location: Yadkinville,NC
Posted: Tue Sep 26, 2017 9:13 am Post subject: Turbochargers |
I have a S2 931 that I have installed a rebuilt S1 turbocharger on. I have continually chased hot running problems that initially were fuel related due to dirty fuel infrastructure which I have hopefully addressed. In the Porsche FSM it says that the different chargers are not interchangeable. Is this true.
Frank
1982 931 _________________ Frank Wood
82 931 |
Posted: Tue Sep 26, 2017 3:37 pm Post subject: |
Does your car work?  _________________ Supercharger and EFI kits
fwood
Posted: Wed Sep 27, 2017 1:10 am Post subject: |
Yes. I have checked wur,Aav,fuel distributor,changed fuel pump and filter,cleaned fuel tank,all vacuum lines are good. It starts cold beautifully, idles strong,runs good until I drive for a while then it starts to starve out,with slight backfire, at which time it seems to almost overheat and die. After throughly cooling will go through the same process. I don't remember having this problem with the Original s2 turbo except when the fuel filter clogged which is clear now. I changed turbos because of an oil leak in the original and I got an s1 turbo that looked to be in better shape whichI had rebuilt. _________________ Frank Wood
82 931 |
Posted: Wed Sep 27, 2017 1:58 am Post subject: |
Your problem is probably not the turbo.
They are interchangeable, meaning they will bolt on and the car will run fine. _________________ Supercharger and EFI kits
Posted: Wed Sep 27, 2017 3:03 am Post subject: |
| morghen wrote: | Your problem is probably not the turbo.
They are interchangeable, meaning they will bolt on and the car will run fine. |
Agreed. First thing I would try is replacing the ignition module on the inner fender well. There have been a few recent reports of these causing symptoms like what you're describing when the heat sink glue dries up and disintegrates. These can be gotten new for very reasonable cost. _________________ erstwhile owner of just about every 924 variant ever made |
Dutch924-racer
Joined: 23 Jul 2007 Posts: 1081 Location: The Netherlands
Posted: Wed Sep 27, 2017 4:24 am Post subject: |
I drove a s1 turbo on a s2 for a couple of years, no problem at all! _________________ 937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
Forge recirculation valve + boost controller |
Posted: Wed Sep 27, 2017 4:55 am Post subject: |
Many frankenturbo’s out there and the owners are none the wiser. PRevious owners and garages have been mixing them up for nearly 40 years  _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
fwood
Posted: Sun Oct 01, 2017 9:50 am Post subject: |
Thanks for those replies. I will try the ignition module. This is one of the best forums with absolutely priceless help.
Frak _________________ Frank Wood
82 931 |
