My 1980 931 4 bolt turbo need some info and advise
Goto page Previous  1, 2, 3, 4
Kg1961
PostPosted: Wed Sep 13, 2017 5:53 am    Post subject: Reply with quote
So swapped everything and got a clean working cis
So new fuel pump now I have to find where the he'll the 02 sensor wire goes it's on the ground at the down pipe
Anyone I can not see a area to switch it with a plug
PostPosted: Wed Sep 13, 2017 12:55 pm    Post subject: Reply with quote
If my poor memory serves, the connector is round and its on the firewall near the coil.
Kenodog
PostPosted: Wed Sep 13, 2017 1:16 pm    Post subject: Reply with quote
Doesn't matter. Leave it unplugged and the Lambda will switch to safe-mode and still run fine.
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
Kg1961
PostPosted: Wed Sep 13, 2017 2:24 pm    Post subject: Reply with quote
Your sure kenodog? I would rather leave it and not worry about that part
For the life of me I can't get this car started
Change
Fuel pump
Fuel relay
Fuel filter
Cis with a working one
Air filter
Plugs
Cap rotor
Fresh battery
Drained the tank fresh fuel
I have to test my relay for power tomorrow and the pump even when I jumped the relay I could not hear the pump on.
924-76
PostPosted: Wed Sep 13, 2017 9:28 pm    Post subject: Reply with quote
+1, I ran mine a long time like this
1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP
Kg1961
PostPosted: Thu Sep 14, 2017 12:01 pm    Post subject: Reply with quote
Great new thanks guys one less thing to worry about
I'm going to add new grounds clean the old. Battery terminal or replace it if needed
Check to make sure I have 12volt and jump the pump check the wire are the back to make sure I Don't have a break.
Nope it gets her to start and run
New injector and spark plug wire are on there way also with some replacement trim items I wanted
Kg1961
PostPosted: Fri Sep 15, 2017 7:45 am    Post subject: Reply with quote
So I got more parts in.
I'm going to work on the grounds and test items
It cleaned up in calgary so tomorrow will be a busy day
Hope I can get this to work
Kg1961
PostPosted: Sat Sep 16, 2017 3:22 am    Post subject: Reply with quote
So changed some grounds
The car seems to crank stronger
Still not start
There was mud and water at the rear ground in the trunk
So I tried to test the relay point #30 and #87 and nothing zero no power
So now what should I do
I could wire it hot or switch with the audio deck or something
Can someone give me a idea thanks
Kg1961
PostPosted: Sat Sep 16, 2017 7:33 am    Post subject: Reply with quote
Jumped the fuel pump and she runs
Yes
Now it is about to over heat
Sensor switched themostate opened
No fan
How or what do I look for to get the fan to work I can also hardwire it if needed
Lmk
PostPosted: Sat Sep 16, 2017 11:49 am    Post subject: Reply with quote
The switch on the radiator is usually open. When it hits its setpoint, it closes and provides a ground to the fans.
Kg1961
PostPosted: Sat Sep 16, 2017 1:58 pm    Post subject: Reply with quote
So Paul that does not help me what to check or do?
PostPosted: Sat Sep 16, 2017 10:35 pm    Post subject: Reply with quote
If the switch is open meaning when measured with an ohm meter (with the wires disconnected) you are getting a reading of infinity, the switch is not asking the fans to run.
This means:
1) the coolant has not gotten hot enough to close it.
2) the switch is bad (unlikely)
My next step would be to (with the ignition switch on) connect the 2 radiator sensor wires together and see if the fans run.
Try this and check back for more help.
BTW it is common for the temp gauge to read high on these cars due to dirty grounds.
Kg1961
PostPosted: Sun Sep 17, 2017 5:05 am    Post subject: Reply with quote
Ok will try Monday but it was almost to the red.
This was the first time coolant was back in the car also
And the thermostat opened I topped it up
I will check the sensor and try the jumping item
To test the fan
PostPosted: Sun Sep 17, 2017 12:16 pm    Post subject: Reply with quote
Make sure you bleed the cooling system if you haven't already. Air pockets will cause overheating.
Kg1961
PostPosted: Mon Sep 18, 2017 5:29 am    Post subject: Reply with quote
Think I did it right so I will see now on Tuesday my day off the kids day home is closed monday so don't think I i will get to it
Page 4 of 4
