My 1980 931 4 bolt turbo need some info and advise
Goto page Previous  1, 2, 3, 4  Next
Kenodog
PostPosted: Tue Aug 22, 2017 1:48 pm    Post subject: Reply with quote
I think you need to buy a Haynes manual...lol
If you have the hood up and are standing at the front of the car looking at the motor the hose you need is coming out of a hole to your right just in front of the firewall. It goes to the canister that is tucked behind the antenae inside the drivers front fender well. There will be a black round plastic puck at the firewall with the hose coming in/going out and a small 4mm vacuum line that opens and closes the valve to let the vapour flow through that line and into the airbox when the motor is running.
Me
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
Kg1961
PostPosted: Thu Aug 24, 2017 10:32 am    Post subject: Reply with quote
Man thanks I will look tomorrow
Kg1961
PostPosted: Fri Aug 25, 2017 3:25 am    Post subject: Reply with quote
Thanks foubdnit what a stupid place to put a item..lol
Kg1961
PostPosted: Fri Aug 25, 2017 3:26 am    Post subject: Reply with quote
Now the car will start and turn over first time
Runs for a couple second than starve for fuel
I'm changing the fuel filter today hope that works
Kenodog
PostPosted: Fri Aug 25, 2017 7:25 am    Post subject: Reply with quote
If the car has been sitting the first thing to change is the filter. Even though the filter in Olive was relatively new when she was parked 10+ years prior I believe it was this that cooked the fuel pump and fuel pump relay. It just has to draw so much current trying to force fuel through a plugged filter that it cooks itself and fries the electrical system.
Even after driving it for 1,000 miles with tank after tank of Techron when I finally pulled it from the car the dark brown spittle looking shite that came out of it was horrendous. I honestly think there is no better investment than a $17 fuel filter.
As an aside, Techron is an OUTSTANDING product for cleaning the fuel system.
Leg
1981 931, Sabine
2024 KLX300
2024 KLX140
Kg1961
PostPosted: Fri Aug 25, 2017 10:48 am    Post subject: Reply with quote
Filter is changed so I need to test the pump tomorrow by jumping it
Than I will see what it needs
PostPosted: Fri Aug 25, 2017 11:20 am    Post subject: Reply with quote
You did install the filter with the arrow pointing backwards, correct?
Kg1961
PostPosted: Sat Aug 26, 2017 7:32 am    Post subject: Reply with quote
I pointed the filter with the arrow pointing forward towards the engine not the back of the car?
I had a long day and wife is getting mad I keep working on the car
So Monday I will test the pump and replace the relay or pump and go from there
I think I should drain the tank but it's almost full where do you dump that..
Kenodog
PostPosted: Sat Aug 26, 2017 9:38 am    Post subject: Reply with quote
The arrow indicating flow direction on the filter should point to the rear of the car. As for the tank of fuel just go to Home Despot and buy a few 5 gallon pain for $4 each and used those to temporarily store the fuel from the car. If the gas is questionable then you will need to store it in fully sealed containers until you can manage to burn through it with your lawnmower.
Moi
1981 931, Sabine
2024 KLX300
2024 KLX140
Kg1961
PostPosted: Mon Aug 28, 2017 1:11 am    Post subject: Reply with quote
I will change it and drain the tanks I can shop vac it out if there is crap
And than but new fuel i have the injector cleaner everyone said.to buy
PostPosted: Mon Aug 28, 2017 2:31 am    Post subject: Reply with quote
Shop vacs and gasoline vapors could cause an explosion.
Kg1961
PostPosted: Thu Aug 31, 2017 10:48 am    Post subject: Reply with quote
So update
Drained the car
Blew out the lone
put new fuel in
The relay and pump seem dead. Going to change them
I tried to jump the relay but still did not hear the pump
I will check to make sure 12v is getting back there
So relay and pump are on order I'm going to buy new injectors and I have a cleaned cis from a working parts car coming my why so get this going
She tries start for half a second and that's it
So back to the drawing board
If anyone can digest anything else lmk
PostPosted: Thu Aug 31, 2017 4:27 pm    Post subject: Reply with quote
fuse for the fuel pump blown?
Kg1961
PostPosted: Sun Sep 03, 2017 10:41 am    Post subject: Reply with quote
Checked not the fuse
Ordered new injectors new cap rotor
Got a working cis
And some other parts
When everything show up
I will install this car better work
Kg1961
PostPosted: Fri Sep 08, 2017 11:13 am    Post subject: Reply with quote
Pump, relay showed up same with a work cis
System
I ordered injectors
Think I should install it and try or wait for the injectors
I have below the back of the engine what looks like a o2 sensor in the muffler system
There is a wife now about 10inch long off of it
I can not see where it broke from
Does anyone know where the wire.starts in the engine bay and I will find it and follow it down
Thanks again
Mike
Page 3 of 4
