Rhubie
Posted: Thu Jul 27, 2017 7:37 am Post subject: Spark problem? |
My car is getting fuel, air, and proper compression
I know all that
She dies immediately after she starts. With my foot on the accelerator and off
How do I test the spark after ignition? Or could she be getting flooded? _________________ 1980 Porsche 924 Weissach Commemorative Edition |
Rhubie
Posted: Thu Jul 27, 2017 8:03 am Post subject: |
3/4 injectors are bad.. including a new one
Problem? Lol _________________ 1980 Porsche 924 Weissach Commemorative Edition |
agfisher
Joined: 09 May 2007 Posts: 484 Location: West Hartford, CT
Posted: Thu Jul 27, 2017 10:37 am Post subject: Re: Spark problem? |
| Rhubie wrote: | | She dies immediately after she starts. With my foot on the accelerator and off How do I test the spark after ignition? Or could she be getting flooded? |
Do you have an inductive timing light? _________________ 1977 924 N/A Martini Edition |
Rhubie
Posted: Thu Jul 27, 2017 10:48 am Post subject: |
I do not.. Inexpensive? _________________ 1980 Porsche 924 Weissach Commemorative Edition |
agfisher
daniel
Joined: 18 Jun 2009 Posts: 686 Location: Sydney, Australia
Posted: Thu Jul 27, 2017 3:21 pm Post subject: |
Their is a cold start valve in the intake manifold which squirts a bit of fuel in to enrichen the starting mixture. This may be the only part of your fuel system that is working and would explain your symptoms. Pull all 4 injectors and lift the plate in the fuel distributor to ensure fuel is coming out.
I doubt the ignition would be responsible for what you describe _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
Rhubie
Posted: Fri Jul 28, 2017 10:42 am Post subject: |
So I did that.. All injectors spray but not perfect mist... A little better though. I did notice that the MAF needed to be brought up 2 cm to spray though. Maybe a little over exaggerated but it was abnormally high I feel. Do I need to readjust the MAF or new injectors? _________________ 1980 Porsche 924 Weissach Commemorative Edition |
daniel
Posted: Fri Jul 28, 2017 10:48 am Post subject: |
Was the fuel pump running when you tested the injectors? _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
Rhubie
Posted: Fri Jul 28, 2017 1:43 pm Post subject: |
I did. Jumped 30 to 87 with a some wire, a house light switch and a 10 amp fuse so I dont fry anything. _________________ 1980 Porsche 924 Weissach Commemorative Edition |
Rhubie
Posted: Sun Jul 30, 2017 6:48 am Post subject: |
Dumb me... I used a thicker O ring that makes an air tight seal between the MAF and fuel distributor. It pushed it up 1/3+ of a cm so im not getting any fuel whilst at low RPMS
Im gonna put in my new injectors before I try to start her again... But after that I can only think of the cold start valve or the warm up regulator to cause my non starting issue. _________________ 1980 Porsche 924 Weissach Commemorative Edition |
Posted: Sun Jul 30, 2017 8:33 am Post subject: |
A good starter setting for the AFM screw is go rich just until the injectors spray with the plate at rest and then back lean just until they quit spraying, with the fuel pump jumped ofcourse, injectors in bottles helps..
That should get you started and then adjust from there.. _________________ 80 Turbo - Slightly Modified |
Rhubie
Posted: Sun Jul 30, 2017 8:57 am Post subject: |
Yeah that was the plan.. Just got to get everything in order first before I start to calibrate and such. _________________ 1980 Porsche 924 Weissach Commemorative Edition |
