toast54
Joined: 08 Sep 2014 Posts: 106 Location: Oklahoma City OK
Posted: Mon Jul 03, 2017 11:58 pm Post subject: Speedometer cable |
| I'm working on wheel bearing adjustment on my 924S (among other things). The left side has the speedometer cable that comes through the bearing cap, held in place with an e-clip. Is there a trick to getting the cable back through the cap or does it just require a lot of patience? Seems to slide off to one side or the other then I have to start over. Thanks |
Posted: Tue Jul 04, 2017 2:45 am Post subject: |
Tie a piece of fishing line to it and pull it through?
I usually just push on the cable from the back of the spindle while slowly rotating the wheel. _________________ White 87 924S "Ghost"
toast54
Posted: Tue Jul 04, 2017 5:30 am Post subject: |
| I'll try flossing it. Thanks for the idea. |
Andre'
Joined: 21 Feb 2009 Posts: 85 Location: North Carolina (Blue Ridge Mountains)
Posted: Tue Jul 18, 2017 7:57 am Post subject: |
| Remove the grease cap first. Insert you tachometer cable and reinstall cap. Plenty of cable length available. Secure cable in cap. |
