mikeycrum14
Joined: 19 Jan 2017 Posts: 110 Location: Juneau, Wisconsin
Posted: Tue May 09, 2017 2:01 am Post subject: How to fix front valance? |
What is the best way to approach this repair?
replacement is not an option unless its dirt cheap.
how do i pull the valance?
sand and prime and repaint?
http://i682.photobucket.com/albums/vv182/mikeycrum14/IMG952017011995210921_zpsrzz7my2r.jpg
this is what it looks like right now...  _________________ 1981 924 - Alpine White, First car! LSD. - SOLD
1989 Foxbody - Oxford White Turd
1992 Miata - Freaking Red
1987 300zx Turbo - Also White
1991 Miata - White field find
1987 924S - Alpine White, Offroader Build, possible future TDI swap |
edredas
Posted: Thu May 11, 2017 11:24 am Post subject: |
I've repaired a few of these. There are a some 10mm bolts and screws holding it on... so not terribly hard to remove. Once it's off you can straighten it out and use fiberglass filler to smooth it out.
The panel was textured from the factory and SEM heavy texture chip guard is a great, if not perfect match. Then you can primer and paint over top!
I hope that helps! _________________ '84 944 -White, Brown interior
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver |
mikeycrum14
Posted: Fri May 12, 2017 12:07 am Post subject: |
Cool. will post progress once i get onto doing the repair. _________________ 1981 924 - Alpine White, First car! LSD. - SOLD
