chris79
Posted: Mon Mar 06, 2017 2:09 am Post subject: New shock absorbers |
What do you think of this shocks?
Can be considered semi-sport dampers for road and trackday?
http://www.ebay.co.uk/itm/331717173775 _________________ Porsche 924 2.0 na 125hp (1979) euro
Alfa Romeo Spider "Duetto" 1.6 104hp (1986) euro |
chris79
Posted: Thu Mar 16, 2017 2:55 am Post subject: |
Nobody can send me some informations about this dampers? I'm evaluating replace shocks and this sachs seems a good compromise. My first choice are bilsten but this solution is cheaper.
Thanks _________________ Porsche 924 2.0 na 125hp (1979) euro
motormouth
Posted: Thu Mar 16, 2017 4:27 am Post subject: |
Aren't those sachs just replacement for original damper, nothing extra sporty? _________________ 1980 924 Turbo
chris79
Posted: Thu Mar 16, 2017 5:23 am Post subject: |
Ahahah no no very out of my budget 😁
Maximum I can buy bilsten b6, in eBay less than 500 euro _________________ Porsche 924 2.0 na 125hp (1979) euro
Posted: Thu Mar 16, 2017 6:06 am Post subject: |
Search harder https://www.amazon.co.uk/d/Car-Shock-Absorbers-Accessories/Bilstein-24-020527-BILSTEIN-24-020527/B0068NXH62/ref=sr_1_2?s=automotive&ie=UTF8&qid=1489330345&vehicle=92-1186-208-2985-1-0&sr=1-2
Rears were £57 each _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
chris79
Posted: Thu Mar 16, 2017 8:16 am Post subject: |
I found this kit in eBay:
http://www.ebay.de/itm/381891820776
It seems a good price. _________________ Porsche 924 2.0 na 125hp (1979) euro
Posted: Fri Mar 17, 2017 12:33 am Post subject: |
You might also check to see what GAZ has to offer although for long term reliability the Bilsteins might be best. _________________ Mike
Johann
Posted: Fri Mar 17, 2017 1:57 am Post subject: |
These are the wrong ones, the add states that the set consists out of 34-000403 and 24-001618. However, you need 34-000403 and 34-001042.
Have a look here for more info
chris79
Posted: Fri Mar 17, 2017 2:05 am Post subject: |
But this is a kit, why is wrong? _________________ Porsche 924 2.0 na 125hp (1979) euro
Johann
Posted: Fri Mar 17, 2017 2:11 am Post subject: |
Sorry I gave you the wrong numbers, you need
Front: 34-001042
Rear: 24-001618
34-000403 is for a beetle. The 924 and beetle share the same struts but there is vast difference in weight they have to carry. For this reason the 924 has a different rating for the insert. |
chris79
Posted: Fri Mar 17, 2017 2:29 am Post subject: |
This kit and another similar in eBay have this part number, then they are all wrong? _________________ Porsche 924 2.0 na 125hp (1979) euro
Johann
Posted: Fri Mar 17, 2017 3:06 am Post subject: |
| Yes if 34-000403 is used for the front it is wrong. |
chris79
Johann
Posted: Fri Mar 17, 2017 5:44 am Post subject: |
The compression and rebound specs are different between the two inserts. I am by no means an expert on this, but the consensus between the experts are that 34-000403 is not the correct option.
Page 43 in this manual also mentions both options, so I guess as long as you buy the set as stated in the manual you should be okay.
I think the 34-001042 is the sportier insert. |
