Posted: Sun Feb 26, 2017 2:08 am Post subject: |
Hold on, except the boost, there is no difference between the euro S1 and the US S1, is there?
Just turn up that boost to 0.7 man...you don't need to invest in anything else to have yourself a quick 924.
Just make sure you've got fuel to cover that boost and you're ready to go...no need for modern engine management witchcraft unless you want to get more than 200hp out of the S1. _________________ Supercharger and EFI kits
Posted: Sun Feb 26, 2017 3:21 am Post subject: |
Mine's an S2... and I'll leave it to Dan to answer the detailed tech questions like that! LOL
But yeah, at least I now have the right gauges to tell me if everything's happy... so game on!
Just need to wait for the snow to leave again, for good... and then find room for a few more hoses through the firewall!!  _________________ Vaughan Scott
Posted: Sun Feb 26, 2017 4:51 am Post subject: |
| morghen wrote: | | Hold on, except the boost, there is no difference between the euro S1 and the US S1, is there. |
Euro lacks the frequency valve, and therefore the WOT enrichment circuit, no? _________________ Toofah King Bad
Posted: Sun Feb 26, 2017 5:25 am Post subject: |
Don't know for sure but nothing stopping you from upping the boost while still staying safe if you use high octane fuel. Must not be race fuel but I've tested that on my GTS wannabe and it makes a difference even from high octane pump fuel. _________________ Supercharger and EFI kits
Posted: Sun Feb 26, 2017 1:02 pm Post subject: |
DITC is different on Euro S2, so presumably a different ignition map.
Bumping a US S2 from 7psi to 10psi should be relatively safe as long as you're not stupid, and take care on the hottest summer days. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Thu Mar 30, 2017 9:57 pm Post subject: March update |
Time for a little update... drove 'er to work last three days, thanks to the salt finally clearing away. Lots of fun! Until I got stuck at the gas pump refueling on the way to work. Typical hot-start starter-based issue.
Will be redoing the wiring to the starter, plus the battery ground (replaced them some time ago, but will be doing a better job this time) and a new gear reduction starter from Ideola. Enough of this stupidity.
I also noticed that my clutch master cylinder is dripping at the boot, so will swap that out too before it becomes a problem.
Then maybe soon I can get to installing the boost controller and really having some fun! Mixture/AFR and general running have been going quite well... though she is consuming a fair bit of oil at the moment; will probably switch back from Mobil1 to dyno oil for the summer, beat on her hard, try and get those rings to seat in better... _________________ Vaughan Scott
Posted: Fri Aug 04, 2017 12:12 pm Post subject: |
| 924RACR wrote: | | Rasta Monsta wrote: | | 924RACR wrote: | | I had previously removed the electronic component. . .to clean off corrosion. |
What did you find in there? Is this good maintenance? Are there alternative plug and play solutions for this part? |
I seem to recall some corrosion (was at least at the beginning of this year, if not earlier).
No, apparently this was not good maintenance! Maybe if I'd used some proper conductive paste (like from Radio Shack or other electronics supply place).
I'm tempted to re-paste it and reinstall, see if the problem returns. Glad to hear that it's a common part...
According to the photo of the one I took off, I see part # 211 905 351, mfgr is Fairchild, and it's clearly marked VW/Audi.
Edit: exactly this part:
http://www.ebay.com/itm/like/151747513189?lpid=82&chn=ps&ul_noapp=true
$30 on eBay, apparently there are new ones too. Hell, that one above is around the corner from me! LOL
Yeah, Walmart sells a new one!
https://www.walmart.com/ip/NEW-IGNITION-CONTROL-MODULE-FITS-EUROPEAN-MODEL-1979-1989-VOLKSWAGEN-211-905-351A-B-D-0-227-100-116-0-227-100-118-0-227-100-137/113340650?wmlspartner=wlpa&selectedSellerId=1134&adid=22222222227050039562&wmlspartner=wmtlabs&wl0=&wl1=g&wl2=c&wl3=145320267749&wl4=pla-261006180645&wl5=9016902&wl6=&wl7=&wl8=&wl9=pla&wl10=112343853&wl11=online&wl12=113340650&wl13=&veh=sem
One more, original part # (per the PET parts catalog) is 191 905 351 A... Google search shows it turning up as a VW Golf Mk1/Mk2 ignition control module...
PS - thanks to John Brown for providing the part! |
A couple of additional part numbers for the ignition module that come up in a cross reference search:
211 905 351
0 227 100 137 (Bosch)
93 90 220 (Beru)
Audi - Volkswagen OE #: 211 905 351 D
Saab OE #: 9390220
Volvo OE #: 1389939
Alternate, update or replacement for Bosch #'s:
0227100142, 0227100139, 0227100113, 0227100116
Alternate, update or replacement for Audi - VW #'s:
191905351B, 211905351B, 211905351E
Alternate, update or replacement for Volvo #s:
285230
191 905 351B => this one includes the heat sink. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Thu Oct 19, 2017 9:33 pm Post subject: Time for modern electronics? |
Ugh. About ready to give up on this damn thing and take the plunge to Megasquirt.
Still have a few more things to check, but the lack of consistent starting is killing me, keeping me from being able to drive this poor car that desperately needs miles.
It's now at the point where it won't start except with full throttle... and when hot will only start with starting fluid. Need to check the fuel pressures when this is happening... but it's really behaving nothing like it did before I tore it all apart for the rebuild.
Ignition, I'm fairly confident is OK; spark may be a bit suspect when cranking, but that'd be a simple matter of power distribution, and could readily be resolved by installing a starter relay as I have on the 924 racecar - so may try that soon.
I also have a data acq system I can borrow from my other (prototype) racecar (actually already removed, for the winter) and use to log data on voltages at various spots while cranking (like ignition power, fuel pump power etc).
Already have the fuel rail for the conversion, and the injector cups... lessee, what else... crank sensor and trigger wheel, injectors and pressure regulator... whatever other sensors, I think MAP and IAT right? Then just an ECU, I think...
So annoying... _________________ Vaughan Scott
Posted: Thu Oct 19, 2017 10:03 pm Post subject: |
You're overthinking it and about to overdo it.
If it runs well once it starts then the spark is just fine.
Your problem is surely with the fuel pressures, AFR mixture and who knows, maybe vacuum leaks as well.
Do a pressures test cold and hot. install a wideband afr sensor and gauge.
My red car has hot start problems as well, it will start with some cranking but it will start quickly with WOT applied because the fuel vapours go out the injectors immediately when the intake lifts the CIS plate. _________________ Supercharger and EFI kits
Posted: Thu Oct 19, 2017 10:56 pm Post subject: |
Yeah, you guessed correctly but I neglected to mention, it does run pretty good once started.
I do have a wideband O2 and gauge - but can't see anything meaningful when cranking of course.
Have been all over the map trying to find mixture settings to make it work normally again. I could totally see the WUR failing again, and will have to do some soul-searching to decide if I want to again get a rebuilt... though still admittedly cheaper than the EFI conversion... _________________ Vaughan Scott
Posted: Thu Oct 19, 2017 11:16 pm Post subject: |
Vac leaks is a problem too, thanks to one recalcitrant injector cup that is stripped out... have an old spare, plus new cups for EFI conversion; if time permits, I may see if I can cut the weak plastic bit off the brass center screw-in mount for the 931 injector, and epoxy it into the new/replacement cup to allow me to eliminate that leak... _________________ Vaughan Scott
Posted: Sat Oct 21, 2017 10:40 am Post subject: |
| morghen wrote: | You're overthinking it and about to overdo it.
Do a pressures test cold and hot. |
So yeah...
System pressure was barely over 5.0 bar... managed with much work to get it up to 5.5, still weak (with every shim I had around). Suspicious of poor power supply to the fuel pump - have to dive into that tomorrow (did already check the ground).
Control pressure is WAY low - around 1.0-1.5 bar, not even quite getting to 2.0 (cold/20C ambient, no power/heat to the WUR). So pulled that out, and will be seeing about tweaking it to get that back up (as well as cleaning)... fingers crossed... _________________ Vaughan Scott
Posted: Sat Oct 21, 2017 9:50 pm Post subject: |
Added detail on the pump power supply; plugging in the frequency valve cost me 0.1 bar alone, when I was sitting there with the relay jumpered...
Gonna take a few minutes and trace the voltage supply level through the wiring loom... _________________ Vaughan Scott
Posted: Thu Feb 22, 2018 7:33 am Post subject: Overdue update |
As hinted at in another thread... after some prodding finally dealing with my naughty WUR.
Final symptoms on removal, system pressure is still 5.5 bar or so, but cold control pressure still junk at around .5bar.
Talked to Special T Auto (the DeLorean guy and CIS rebuilder) the other night, was very helpful. I was quite concerned that those symptoms didn't match a balky WUR, but he mentioned he'd actually just finished up rebuilding a DeLorean WUR with exactly the same symptoms: similar pressures, and wouldn't run or ran pig-rich when it did! Happiness!
Even better, he's got one on the shelf ready to go, so I'll be shipping mine out to him for a swap, and by the time I get home from my next work trip, it'll be ready and waiting for install, just in time to enjoy this nice warm spring weather we're already having in the D...
Now, off to Sweden for a couple more weeks of winter!  _________________ Vaughan Scott
Posted: Thu Feb 22, 2018 7:45 am Post subject: |
Nice, i hope it turns out well, i good working WUR makes so much difference! Got a special T rebuilt aswell, pricey but works well.
Welcome to sweden and good luck with the testing, i hope the weather will be cold and nasty, which is what everyone wants up there . I tend to stay away from winter testing, i only do summer testing in Spain, much more comfy, though Sierra nevada can be a bit more exciting than you would want in a big truck.. _________________ 1980 924 Turbo
