Where can I buy AOS vacuum lines?
Johann
PostPosted: Tue Sep 13, 2016 9:25 pm    Post subject: Where can I buy AOS vacuum lines? Reply with quote
As you are aware I am in the process of restoring a 1983 ROW 931. I have now replaced most of the vacuum lines, but am unable to find a source for the AOS lines.
I need the following pipes:
931.107.169.00
931.107.171.00
931.107.394.02
Can anyone please point me to a source where I can buy these?
Johann
PostPosted: Fri Sep 16, 2016 4:33 pm    Post subject: Reply with quote
Has no one replaced their AOS lines recently?
PostPosted: Fri Sep 16, 2016 9:02 pm    Post subject: Reply with quote
Use generic rubber or silicone for nla parts
PS I tried to search those parts numbers for a quick reference. Real hard to locate easily. So no one is going to answer if its too hard to understand the question or part you need. Try posting an image of PET page with the parts highlighted or numbered. Easier for us to help
Johann
PostPosted: Fri Sep 16, 2016 9:13 pm    Post subject: Reply with quote
Thanks for the advice. I am trying to keep my 931 100% stock so original Porsche spec pipes would make my very happy. My last resort would be generic hoses. I am looking for 27, 35 and 36 in the picture below.
PostPosted: Fri Sep 16, 2016 9:22 pm    Post subject: Reply with quote
All NLA. You can try contacting your local Porsche dealer to see if there are any languishing on a back shelf of a dealer somewhere in Europe, but that is about your only chance of getting OEM parts.
Johann
PostPosted: Fri Sep 16, 2016 11:18 pm    Post subject: Reply with quote
Yeah, I still cannot get used to the fact that so many parts are NLA. On my 964 and even my previous 356 this is so much easier, 98% of all parts are still readily available.
Luckily with enough patience and help from forums such as this one I am managing to locate all the parts I need.
My latest find is the rubber pipe between the AFM and Turbo. My car had a silicone tube that has been sucked flat causing the car to feel suffocated at high revs.
Bit by bit I am bringing this car back from the dead
PostPosted: Sat Sep 17, 2016 12:01 am    Post subject: Reply with quote
Issue is, Porsche can charge a lot more money when recommissioning 911 or 356 part v's 924. Plus the 924 market place has probably been shrinking at OPC for many years. That said they are adding new 924 parts back into the line every quarter. Just because it was NLA does not mean it remains NLA. The rubber hoses into and out of the waterpump are now available again.
The woven pipe can be bought from motor factors or VW Heritage
The rubber pipes into the Purolator are not OEM deal breakers for generic rubber hoses?
Zuff911
PostPosted: Sat Feb 18, 2017 6:18 am    Post subject: Reply with quote
Johann,
I just replaced #27 on my '80 931, on my car this is wire re-enforced rubber with a woven cloth sheath as is #35 and #36. I was able to locate what I think is the factory hose and had to buy 2 meters of it. If your '83 is similar let me know because even after replacing my #35 and #36 I'll have lots left over.
-Brad
1976 911S
1973 911T
PostPosted: Sat Feb 18, 2017 4:28 pm    Post subject: Reply with quote
Erie, CO! Nice! Native Coloradoan and CU alum here. . .
Johann
PostPosted: Sat Feb 18, 2017 9:09 pm    Post subject: Reply with quote
Thank Brad, I sent you a PM.
