Johann
Posted: Sat Jan 28, 2017 12:31 am Post subject: |
Couldn't agree more Dan. My Turbo ran quite rough when I just finished restoring it, Everything was within spec but after 3000km it runs perfectly smooth (well, as smooth as a toofah can be). I truly think things need to settle and go through a couple of heat cycles to find their sweet spot again.
Why drive it hard? because you need to get parts of your system very hot again and that only happens when you drive it hard. Hit the red line often, don't shift up for a while etc. You will see that valves, hinges, pumps, bearings, etc start working better. You will burn carbon deposits and by increasing the amount of fuel flowing through the system your injectors will clean themselves.
Just one more tip use contact spray or WD40 on all electrical connectors...it does wonders for conductivity. |
Posted: Sat Jan 28, 2017 2:17 am Post subject: |
Suggested the same back on P9. He ain't buying it. _________________ Toofah King Bad
Posted: Sat Jan 28, 2017 4:59 am Post subject: |
I remember back when carbs were the thing and cars were moody, somehow human. Then fuel injection changed them closer to machines and then electronic fuel injection further stripped them of any seemingly human characteristic. Maybe that's why we don't love new cars...they are sterile and don't resemble humans at all.
Anyway, the CIS is a good system, reliable and performant even compared to much newer generations of systems might I add. However it still has that human feel in my opinion. Its strong and can perform great, but its delicate and influenceable, its a little bit imprecise and even to a small degree moody.
My S1 931 had a similar condition when cold, it would shutter and it even seem to misfire. I looked a bit for a fault, replaced some sparkplugs and the rotor and while it was considerably better it still behaved like that.
I then proceeded in driving the car almost on a daily basis and then taking it for a 3000mile trip.
The rough throat was gone after the first week of daily use and sporty driving if I remember correctly.
Who knows, maybe a valve is binding a tiny bit and that's upsetting the combustion cycle until it warms up.
When the weather allows you take it for some drives, enjoy the car...it might be that whatever is causing the issue you're having will go away by itself by just stretching the legs of the car a bit. _________________ Supercharger and EFI kits
Last Triumph
Posted: Sat Jan 28, 2017 6:54 am Post subject: |
| ideola wrote: | In the spirit of adventure and pursuit of answers, it would be great to pinpoint the problem, but honestly, the symptoms I've seen in your videos are so scant, I'm beginning to doubt that something is "wrong".
What if driving it fixes it? These cars like to be driven, and like to be driven hard. I think there is merit to the idea of thrashing it on some back roads and blowing the cobwebs out, as the saying goes. A few bottles of techron fuel system cleaner and a good hard thrashing has fixed more than one of mine, it might work for you.
If you're going to be a perfectionist about it, then you should send the AAV, WUR, fuel dizzy, and AFM to a CIS specialist and have them rebuilt to as-new. Replace the injector seats, buy new injectors, have them flow-matched, and rebuild all of the lines with teflon coated stainless. You should have the ignition distributor rebuilt (when's the last time you checked the bearing play in it???), and you should find one of those circuit board specialists who can check every component and reflow all of the the solder in the TIU. Also, replace the coil.
<shrug>Why would you allow 2 minutes of rough idle at startup to ruin your enjoyment of what appears to be an otherwise nicely running car??? |
I hear you, but am in the inconvenient position of not having the budget to do all that stuff.
Coil has been replaced, injectors are all new, as are the seals and seats.
I rebuilt the distributor myself (having replaced it with a known working one to no avail).
At the end of the day, once I've rebuilt the metering head, and assuming it doesn't make a jot of difference as is my expectation having seen how clean it looks inside, there'll be nothing else to replace or try other than as you say, give it a bloody good run. That will be another box ticked off the list.
Only time will tell.
I've had a new diaphragm donated to me so just need to find replacement o-rings for the metering head before rebuilding it. |
Last Triumph
Posted: Mon Jan 30, 2017 4:45 am Post subject: |
Not much in the way of an update, but an interesting exercise nonetheless.
I was keen to see just how much additional dirt could be removed using an ultrasonic cleaner using panel wipe spirit as the agent.
My starting point were components that I'd scrubbed with a stiff toothbrush using brake cleaner and then blown out with an air line, then scrubbed again, anywhere I could get a brush or pipe cleaner.
Had I not had access to an ultrasonic cleaner, I'd have reassemble d as is, secure in the knowledge that I had them pretty darn clean.
The results were quite astonishing.
Keeping in mind that the bowl the components were sitting in was stainless steel, and the panel wipe spirit crystal clear when I first switched it on.
This was after 8 minutes...
And the other half of the body on the same cycle...
Just goes to show the difference between clean, and clean.
Everything is now sealed in freezer bags awaiting a rebuild kit, as sadly the donated diaphragm is not up to scratch having been installed previously and suffering a little damage round one of the holes. |
Last Triumph
Posted: Sat Feb 11, 2017 8:59 am Post subject: |
I'e rebuilt the metering head and come across what may or may not be a problem...
The shuttle valve glides effortlessly into the valve body but tightens up that last quarter inch of travel - the part it would normally move through in operation.
I've cleaned, double cleaned, ultrasonically cleaned, lubed, double lubed, cleaned again etc, etc and it's the same every time, the last quarter inch of travel get tight where gravity won't allow it to fall back out again and I have to physically pull it out again.
I was mega careful putting everything back together and made sure everything was aligned perfectly etc so can;t think where I;ve gone wrong.
Have I gone wrong?
Should I expect it to fall freely right to the end of it's travel and clunk against the end of the valve body?
If I assemble it on the air metering unit and raise the air plate to the limit of its travel - wide open throttle position, then remove the metering head, the shuttle vale is stuck in place and I have to gently pull it out with needle pliers by the tip.
Is this normal and would fuel system and control pressure be enough to keep it moving?
Given that the valve body is rigid, I can;t see how reassembly could cause it to get tight at the end of it's travel.
Any ideas? |
Last Triumph
Posted: Sat Feb 11, 2017 9:54 am Post subject: |
Stripped it down and rebuilt it again - it's fine now.
Let's hope it works. |
Fifty50Plus
Joined: 28 Feb 2008 Posts: 1424 Location: Washington DC area
Posted: Sat Feb 11, 2017 2:13 pm Post subject: |
Are all the cold start problems gone now???? If so congrats!!!  _________________ 1979 924 NA race car H-Prod SCCA
1982 924 NA race car - Sold
1981 924 Turbo sold
1982 924 Turbo sold
Last Triumph
Posted: Sun Feb 12, 2017 12:57 am Post subject: |
| Fifty50Plus wrote: | Are all the cold start problems gone now???? If so congrats!!!  |
No - when I said all fine, I meant the plunger in the metering head.
I re-installed the metering head and air flap unit and fired it up.
Took a while to fire and ran really badly as the fuel flushed through any remnants of Vaseline used during assembly.
Once it had cleared it's throat after a minute or two, it was clear it was running really badly, barely idling and lumpy as hell. My heart sank, but I figured I'd check the mixture which was way off, showing very rich which I guess is to be expected after a full rebuild.
I loosely set the mixture which made a big difference and then I let it warm up properly, before doing a proper tune up with idle speed, mixture and timing.
This is the result in a warm engine condition...
https://www.youtube.com/watch?v=eUW2_FPWKpM
From this I can draw the following conclusions.
1) The water pump is still noisy and will need replacing at some point.
2) The idle is rock steady therefore the rebuild process of the metering head has been successful.
3) There are no fuel leaks, another tick in the successful metering head rebuild box.
4) It responds well and the emissions are stable and correct - no issues with the metering head.
5) The metering head has been successfully rebuilt and can now be ruled out of the equation, which given it was the only part of the fuel system left to try, suggests the fuel system is not the culprit.
How it starts and runs from cold remains to be seen, however I fully expect it to be no different than before. I'll know in a few hours once it's cooled down and I can try a stone cold start.
But.... I'm pleased the metering head rebuild didn't cause me issues such as leaks etc and it at least is no worse than before. |
Last Triumph
Posted: Sun Feb 12, 2017 3:25 am Post subject: |
Just tried a cold start and it's as bad as ever - plenty of coughing, spluttering and backfiring up the intake. No difference.
So we can now eliminate the metering head.
Running out of things to check now. |
Posted: Sun Feb 12, 2017 4:40 am Post subject: |
I though we eliminated the fuel system a while ago before you started tearing into it and you found problems with that green wire.. _________________ 80 Turbo - Slightly Modified |
Last Triumph
Posted: Sun Feb 12, 2017 5:14 am Post subject: |
| Fasteddie313 wrote: | | I though we eliminated the fuel system a while ago before you started tearing into it and you found problems with that green wire.. |
The metering head was the last part unchecked - now we can permanently eliminate the fuel system.
I don't buy into the green wire thing, just because one of the cores (likely the outer shield) is giving varying resistance.
Please can someone give me a detailed reason why it would cause my linear improvement with engine temp running condition?
The spark is strong - hot or cold and no amount of wiggling or manipulating the green wire or plug makes the slightest bit of difference when it's running roughly - both at the control unit harness or at the dizzy.
The issues are so perfectly consistent and repeatable time after time after time, and so perfectly related to engine temp that a potential wiring fault doesn't compute - although I'll happily listen to a logical explanation as to how it could be.
Don't get me wrong, I've seen wiring faults on cars before and debugged more than my fair share, but never have I had one where the symptoms present anything like they do here - linear improvement, perfect consistency, engine temp related.
The misfiring up the intake and reluctance to pick up has to be a clue - but I don't know what to. |
Posted: Sun Feb 12, 2017 7:05 am Post subject: |
Are you measuring fuel pressure during start up? I assume you do since this thread is 15 pages long.  _________________ 1980 924 Turbo
Last Triumph
Posted: Sun Feb 12, 2017 7:22 am Post subject: |
| Cédric wrote: | Are you measuring fuel pressure during start up? I assume you do since this thread is 15 pages long.  |
Yep - fuel pressure is text book from cold to hot. |
brian19600
Posted: Mon Feb 13, 2017 3:21 am Post subject: |
I think at this point, I will join the rest and say, drive it for a while. Maybe the problem will worsen or will get better. You've done a lot to it. Get some miles on it. Driving it for a while may give you further perspective. _________________ 78 924 |
