Basic settings for air/fuel mixture?
Goto page Previous  1, 2, 3, 4
PostPosted: Sat May 24, 2003 3:14 pm    Post subject: Reply with quote
Word from the bible from cmxxxi is pretty good stuff .This comes at a time really helpful all post were ,I have the timing set the cam gear at zero and idle at 950rpm Im gonna see what the fuel dizzy is doing just because.
When I had rust in the tank and car wasnt runningwell[when i first bought it] I convinced my self the beam was to dirty and took it all apart problem was I couldnt get it back together I had to get a whole new top picked one up for free though.
Roger
PostPosted: Sun May 25, 2003 12:48 pm    Post subject: Reply with quote
Did the AMFU come off a 924?
1981 924 NA
mustbfaster2
PostPosted: Fri May 30, 2003 3:00 pm    Post subject: Reply with quote
Jdt
mustbfaster2
PostPosted: Fri May 30, 2003 3:01 pm    Post subject: Reply with quote
Just wanted to say thanks for the help guys....everything seems much better now. While tuning all the air and fuel settings i realized that my timing was quite a bit off too. Unfortunately I spent a good hour adjusting everything before I realized this....then had to do it all over again. I was double cheching my specs on timing in my shop manuals and realized that the specs i looked at last time i set it were for a NA...not a turbo. Boy did I feel dumb. All those headaches because of timing.. oh well. It seems to run good now so im off to find the few remaming things i need....a slave cylinder and a motor mount....and then i should be good to go!
Dustin
PostPosted: Sun Aug 10, 2003 2:25 pm    Post subject: Reply with quote
AznDrgn
This is the post
Itll work I think if you print it out and follow directions..
Hope it could helps lots of good stuff there.
PostPosted: Sat Oct 30, 2004 12:32 pm    Post subject: Reply with quote
I found another good post on this topic I was gonna post it though
I cant find it... Anyway are we all dialed in on setting Co,and idle and stuff
hope so. I have a different Tb so alot of this stuff doesnt apply.
PostPosted: Fri Jan 20, 2017 5:46 pm    Post subject: Reply with quote
Hello every 1.Im installing a wide band o2 sensor. What is the correct mix. If I remember its around 13. something, can someone answer this. Motor is non turboed for now stock cp, port and polished head, after market cam, and a header.
PostPosted: Fri Jan 20, 2017 10:11 pm    Post subject: Reply with quote
On a fully warmed up motor, you should set mixture so that the wideband AFR shows steady 14.7 at idle.
PostPosted: Fri Jan 20, 2017 11:02 pm    Post subject: Reply with quote
and about 12,5-12,7 on full load, should be a good start for maximum power.
RC
PostPosted: Sat Jan 21, 2017 3:12 am    Post subject: Reply with quote
Yep that's good on a NA. Read that Joe is talking about an NA here but don't try on your 931, will ya Joe?
Personally run a flat 12 AFR at 200KPa right up to 7K but took it slow and cautions tuning to that level with EFI and constant datalogging. That is somewhere within a few % of maximum power and I'm not racing nor have the balls / pistons to try get nearer 12.5. I doubt anyone could get anywhere near even 12 AFR @ WOT under boost with CIS?
This chart is an excellent general tuning reference.
World`s quickest 924 2L slushbox
Allan @ DTA wrote:
I have no issue with superchargers, they are for guys who want to drive a car rather than talk about horsepower with their baseball cap on backwards
PostPosted: Sat Jan 21, 2017 3:32 am    Post subject: Reply with quote
Fantastic chart, thanks for sharing.
Page 4 of 4
