Glemon
Posted: Mon Jan 16, 2017 5:16 am Post subject: How quick is US Spec Turbo |
I have sold my 924, thinking about getting something different, was thinking something Italian, or maybe even Swedish (Sonett), but I miss the 924, liked the car, and would have kept it if it had a little more oomph. I have not had the chance to drive a 924 turbo, I do know 80s turbos tend to both more peeky and not the torque monsters modern turbos are. Anyway, road tests from prior US spec turbos are all over the map for performance. Seat of the pants how different does a turbo feel from an NA car?
BTW, my car friends think I am crazy, but maybe some will get it here, I just don't care much for the looks and the overall vibe of the 944. There was one local to me, all records from new, clean, low miles, recent T-belt, but I couldn't bring myself to pull the trigger or even contact the seller, must have been a deal, it is gone now.
I would certainly consider an S too. _________________ 88 924S
68 TR250
02 IS300 |
Posted: Mon Jan 16, 2017 5:42 am Post subject: |
A good running S is a joy. I love the 2.5 platform... Porsche basically did everything we tuners strive for on the 2.0 (EFI, four wheel disc etc) plus eliminated the vibration. The engine is silky smooth.
Having said that, there's really nothing like boost, and I enjoy my 931. Would I restore another one? No way.
Test drive a few S models... best Porsche bang for the buck right now, hands down. _________________ Toofah King Bad
Posted: Mon Jan 16, 2017 5:59 am Post subject: |
I am not as big a fan of the S as others. In stock form, I still feel like it lacks oomph, even the 1988 version with the higher compression. However, the mods that I've done to my SE version definitely make quite a significant difference, and the car is (in my opinion) on par with a well-sorted 931 in terms of driving fun.
The 931 has *way* more performance potential, and personally, I much prefer the rarity of the 931 along with the non-linear acceleration. In stock form, it might not be any faster than the S, but it *feels* faster, and I enjoy that experience a lot more than the flat torque curve of the 2.5L motor.
If you go the 924S option, don't even bother with the '87 model. Hold out for the best condition 1988 model you can find. Update all of the dampers, do the timing belt service, and install the Rogue Tuning MAF+NATune. You'll be quite happy.
For the 931, you will almost certainly have much more work to do to make it a reliable driver. There are so many tradeoffs between the S1 and the S2, I don't feel one has an advantage over the other. But the same general rule applies. Buy the best example you can afford. Once you have the 931 sorted, the best bang-for-the-buck mod is a boost controller and a Stage 2 water-meth injection kit. I have this setup on my "941" and run at 12PSI all year long. It has been extremely reliable, and it's a hoot to drive.
And, FWIW, anyone who makes the trip out to Ideola's Garage is more than welcome to take all of my variants out for comparo runs. I have a bone stock S1 931, the 941, the 937, the Club Sport, and a highly modified 924S SE. Each car is completely different in terms of the driving experience and character. _________________ erstwhile owner of just about every 924 variant ever made |
Glemon
Posted: Mon Jan 16, 2017 6:17 am Post subject: |
Thanks Dan, I have driven a couple 944(s) as well as an 924S, but it has been many years. My recollection of the performance was adequate, but not overwhelming by any means, I hada first generation Sentra SE-R at the time, all things being relative, it was about the same as the Nissan. Most all the Ss I have found so far have been 87s, I think they sold more that year.
I sure like the looks of the Turbo, I was looking at the one I think you posted from Nashville in the FSW section, which is in my price range (but a little out of the geographic range) with some dollars allocated for repairs as well. I assume if it has 5 lugs that means it has the M030 or whatever the code was sports suspension option.)
If I were closer to you I would love to take you up on the driving around the models option. _________________ 88 924S
68 TR250
02 IS300 |
Johann
Posted: Mon Jan 16, 2017 6:29 am Post subject: |
The Turbo's are lots of fun. The boost is addictive and it is pretty fast, even by today's standards. It is nowhere near as fast as my 964, but on the fun factor I would say they are close.
Problem is though, they are expensive to get right. Mine was a barn find (Mothballed for 20 years after 13 years on the road with only 115k kilometers on the clock), I paid €10K for it and I have put another €10k into it to get it to where it is now. I think it is very good now, 98% as good as new, and in some ways better. There are some cosmetics and some small details I still want to address.
I am enjoying this car way more than I thought I would. It is just wild enough to scare you slightly and N/A cars will not do that  |
Posted: Mon Jan 16, 2017 6:36 am Post subject: |
| Glemon wrote: | I assume if it has 5 lugs that means it has the M030 or whatever the code was sports suspension option.)
If its a 79 or 80 with a 5 lug then you have a crack at getting a LSD rear end too, ending in /12 on the bottom rib #..
I think that's the one to look for.. With no lsd it's a tossup, lsd tips the scale..
LSD S1 > S2 > non-LSD S1 > 4 lug S1
But you can mix and match the best of everything on any 1 car so it's just about what you are starting with..
But then their is the pasha Trump card..
good pasha 4 lug S1 > LSD S1 > S2 > non-LSD S1
Some other rarer interiors may also come into play as well as some lesser desirable interiors could be a pass.. _________________ 80 Turbo - Slightly Modified |
Posted: Mon Jan 16, 2017 7:21 am Post subject: |
| Johann wrote: | The Turbo's are lots of fun. The boost is addictive and it is pretty fast, even by today's standards. It is nowhere near as fast as my 964, but on the fun factor I would say they are close.
Remember also that RoW 931 has 30bhp or so more than the US version. So we get a little more bang/boost for buck  _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Mon Jan 16, 2017 8:30 am Post subject: |
| Carrera RSR wrote: | Remember also that RoW 931 has 30bhp or so more than the US version. So we get a little more bang/boost for buck  |
S1 Euro @ 170 BHP vs S1 US @ 150 BHP
S2 Euro @ 177 BHP vs S2 US @ 156 BHP
So, about a 20 BHP difference. But this is easily addressed in a US-spec car with a boost controller and water meth kit, which puts you in easy range of 200BHP with no other major mods. _________________ erstwhile owner of just about every 924 variant ever made |
Glemon
Posted: Mon Jan 16, 2017 5:46 pm Post subject: |
After all these years the reliability is almost only a reflection on the mechanical skills/understanding of the owner/owners. That goes for most of old cars.
My 931 has been very reliable, of course you need to do stuff properly in the first place, lots of work and a bit of money. But I really do like the "real" iron block 924s best, but being in the US makes it a little bit different though.
Over here most GTVs and also most other of the 924s competitors have rusted away, but the 924s are plentiful  _________________ 1980 924 Turbo
Johann
Posted: Mon Jan 16, 2017 8:28 pm Post subject: |
Am I understanding this article correctly? The US versions lost the dogleg gearbox in '81? I love my dogleg, it is one of the coolest features on my car  |
Posted: Mon Jan 16, 2017 9:12 pm Post subject: |
RoW 931 is far quicker than in those test results
Posted: Mon Jan 16, 2017 10:17 pm Post subject: |
| Carrera RSR wrote: | | RoW 931 is far quicker than in those test results |
I find it curious that the S1 ROW 931 is quicker in every test than the S2. I've always preferred the better top end of the S1 over the S2 despite the complaints of it suffering from more lag. Also fascinating that the 924S and S2 are virtually tied. I wonder if the S2 931 just had a "bad day" during these tests (noting the different test sources).
By the way, one of the benefits of running a boost controller like the ones I sell is plumbing the vent line into the upper chamber of our 930 wastegates, which prevents creep, aids in turbine spooling, and helps to minimize some of the lag. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Mon Jan 16, 2017 10:41 pm Post subject: |
Fast it ain't - you'll still get pulled by minivans off the line. But yeah, it's a bit faster than the NA. As already mentioned, the fun is all in the non-linear torque curve and the opportunities for tweaking it up.
When I have mine finally properly running post-rebuild and debugged, I'll be dropping in the (951) intercooler and adding one of Dan's boost controller kits, crank that puppy up to 1.0 bar and let 'er rip...  _________________ Vaughan Scott
Posted: Mon Jan 16, 2017 10:43 pm Post subject: |
The only elements on paper that the RoW S2 had on the S1 performance was the bhp went up from 170 to 177bhp and its in gear spool up helped it feel less laggy. The misconception is that the S2 was 'better'. Both have their pros and cons.
(feedback - confusion reins on this forum on RoW v's US spec facts. Often confusing the lay person. Including me which thought that US turbos were strangled at 143bhp and not 150bhp+) _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
