1979 931 build
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
BTRacing
PostPosted: Thu Jan 05, 2017 1:44 pm    Post subject: Reply with quote
Thank you !
Roof panel will be replaced with no sunroof fiberglass panel.
Tip: make sure that your tube notching is very tight.
Spend the time to fit them as close as possible. It takes a while but it is easier to fill the gap and will give you stronger joint.
Make sure that your heat is set right,practice on the scrap piece of tubing to set the welder right.
Take your time.... Cage is your safety.
www.btrpalmbeach.com
2008 Audi S4 Avant daily driver
2008 Aston Martin Vantage
1974 Moto Guzzi Cafe Racer
1979 Glastron CVX 20
peterld
PostPosted: Thu Jan 05, 2017 11:14 pm    Post subject: Reply with quote
Such a nice job.......with beautiful welds. Bravo!
80/81 932/8 ROW
Dutch924-racer
PostPosted: Fri Jan 06, 2017 4:30 am    Post subject: Reply with quote
great project!
Do you have more info/ pictures on the sunroof delete conversion ?
937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
Mike9311
PostPosted: Fri Jan 06, 2017 5:17 am    Post subject: Reply with quote
+1 one on that
tigging a cage, nice!! ...and your fitment of the tubes also very nice
1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
1982 931 wana-be GTR race car
PostPosted: Fri Jan 06, 2017 4:06 pm    Post subject: Reply with quote
Think I spy a late rad support in there...
BTRacing
PostPosted: Fri Jan 06, 2017 11:40 pm    Post subject: Reply with quote
Yes it is late model radiator support. First idea was to run 944T intercooler with GTS intake, but I think I want to build a larger ,custom intercooler that would look closer to original.
BTRacing
PostPosted: Sat Jan 07, 2017 1:03 pm    Post subject: Reply with quote
Just got my fiberglass roof panel. Pretty good quality. I will post some fitment pictures next week.
Dutch924-racer
PostPosted: Sat Jan 07, 2017 4:44 pm    Post subject: Reply with quote
Do you have a picture of the front of the roof above the windscreen ?
Where did you cut is the roof in the front ?
thanks!
937 trackday car
Series 2 engine
Fast road camshaft
BTRacing
PostPosted: Sun Jan 08, 2017 7:59 am    Post subject: Reply with quote
Some of you asked about pictures of roof removed ,here they are
BTRacing
PostPosted: Sun Jan 08, 2017 8:01 am    Post subject: Reply with quote
Dutch924-racer
PostPosted: Sun Jan 08, 2017 5:34 pm    Post subject: Reply with quote
Great, many thans!
How much work was it, you did it all with point drill, and only cut the 'a' pillar?
937 trackday car
Series 2 engine
Fast road camshaft
PostPosted: Sun Jan 08, 2017 6:48 pm    Post subject: Reply with quote
Dutch924-racer wrote:
Great, many thans!
No cut at the a pillar. Just a 'join'. Grind back to expose spot welds and joins.
BTRacing
PostPosted: Tue Nov 24, 2020 9:04 am    Post subject: Reply with quote
BTRacing
PostPosted: Tue Nov 24, 2020 9:05 am    Post subject: Reply with quote
BTRacing
Page 6 of 8
