staticsan
Joined: 19 Jan 2009 Posts: 450 Location: Sydney, Australia
Posted: Tue Nov 29, 2016 6:58 pm Post subject: Fuel pump replacement. |
First, kudos that the new fuel pump from Ideola arrived so fast. That gives me two Saturdays to replacement before I kinda really need the car.
Now for the tricky question - is it possible to replace the inline fuel pump without emptying the fuel tank? I ask because I don't (currently) have any way to empty the tank.
The car is a 1982 924 originally sold in Britain. The fuel pump has been noisy for more than a month, but when I went to drive it the other week, it had stopped entirely (it normally gets driven once a week). I haven't done the electrical tests yet - if it's blown the fuse or cooked the relay (again), I can replace that and then get it to a mechanic to replace the pump. (I know - I should check those before posting.)
The other thing that's worrying me is that the car seems likely to have in-tank pump, too. But I haven't had enough of a look to know. Kind of don't want to tinker with that, mostly because I don't have a way of emptying the tank of fuel!
Okay. I'll stop rambling now.
Wade. _________________ '82 British NA - Which I think I've been very lucky with! |
Posted: Wed Nov 30, 2016 2:32 am Post subject: |
A DIY method is to pinch off the rubber hose from tank with locking pliers, preferably with 'flat' jaws. I'm sure the mechanics that speak in algorithms, will have a more professional approach~! _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
agfisher
Joined: 09 May 2007 Posts: 484 Location: West Hartford, CT
Posted: Wed Nov 30, 2016 3:47 am Post subject: |
| Grenadiers wrote: | | A DIY method is to pinch off the rubber hose from tank with locking pliers, preferably with 'flat' jaws. I'm sure the mechanics that speak in algorithms, will have a more professional approach~! |
That worked for me. I put a couple of "cut to size" paint mixers over the jaws to protect the hose. Be careful. old hose can crack very easily! _________________ 1977 924 N/A Martini Edition |
staticsan
Posted: Wed Nov 30, 2016 10:35 am Post subject: |
I had thought to simply squash the hose out of the tank - good to see others had done this! I'll be careful of the rubber...
I think such "locking pliers" are also called "vice-grips", FWIW.
agfisher
Posted: Wed Nov 30, 2016 11:23 am Post subject: |
You absolutely have many ways to empty the tank, and you should utilize one. _________________ Toofah King Bad
staticsan
Posted: Wed Nov 30, 2016 6:31 pm Post subject: |
No, I don't have a way of emptying the tank (without doing something illegal like sending the petrol down a drain) - without spending more money. Which I was trying to not do as my next payday is still two weeks away.
But I have some wiggle room and I was not going to rush into this. And there's a carparts place within walking distance. And I could even call on some relatives for additional help and advice.
michaelodonnell123
Posted: Thu Dec 01, 2016 5:00 am Post subject: |
Why not just borrow one or two of these?
 _________________ MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500 |
staticsan
Posted: Thu Dec 01, 2016 6:12 am Post subject: |
That's what the relatives are for, if they have one. Probably should buy one myself, anyway.
Posted: Thu Dec 01, 2016 10:11 am Post subject: |
If the fuel hose is so old and worn that it will crack when you pinch or bend it, you should not drive the car (especially in competition) until you replace it.
I have done this job many times without draining the tank. I usually pinch the hose first (in the middle), then disconnect it from the inline pump, then put a bolt into the loose end and secure it with the hose clamp until I'm done with the rest of the job. I like using litter trays from a portable dog kennel to catch any drips during the process. If you're careful not to spill too much, whatever you do drip/spill should evaporate pretty quickly. _________________ erstwhile owner of just about every 924 variant ever made |
dubrict
Joined: 22 Apr 2011 Posts: 150 Location: Horseheads NY
Posted: Sat Dec 03, 2016 12:55 pm Post subject: |
I think the professional approach is to grab the nearest dirty rag, shirt, paper towel, or animal carcass and wrap that sucker around the rubber hose, then clamp that bad boy (not too tight) with vise grips _________________ 1979 924 NA
2009 Chevy Impala
2005 Dodge Dakota |
nickthompson
Posted: Sat Dec 03, 2016 1:06 pm Post subject: |
| I use a 2 inch c-clamp. |
staticsan
Posted: Sat Dec 10, 2016 5:46 pm Post subject: Mission Accomplished! |
New fuel pump works like a charm! And there aren't even any leaks.
I love the satisfaction of having done such a job, but by gum I don't want to do that in again any time soon. At least, not on a 35+ year old car still with the original fuel pump...
So I think I'll keep the '24 for a little while longer.
Wade, amateur Porsche mechanic. _________________ '82 British NA - Which I think I've been very lucky with! |
