fuel jumper line delete
jvandyke
PostPosted: Wed Sep 28, 2016 8:19 am    Post subject: fuel jumper line delete Reply with quote
We had to bypass the fuel dampener because we're waiting on a new jumper line. We ran the supply line straight to the rail.
I still had the vacuum line from the pressure regulator to the throttle body.
It started throwing gas.
I don't understand the pressure reg/damper and vacuum line. I hope to get the jumper in a few days and revert to OEM but my son is dying to run the thing. Can I just plug the vacuum port on the pressure reg and also on the throttle or not? Just to run the car for a few minutes, not drive it or anything.
87 924S project, '83 944 engine,
my son's first car.
edredas
PostPosted: Wed Sep 28, 2016 8:47 am    Post subject: Reply with quote
Sorry, what's throwing gas? The regulator? Hooking the line straight into the rail should work, no problem.
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver
jvandyke
PostPosted: Wed Sep 28, 2016 8:56 am    Post subject: Reply with quote
gas shot out the vacuum line (that's connected to pressure regulator) where it attaches to the throttle assembly, normally it's branched and also connects to the dampener but I had it going straight to the throttle since the dampener was not in the mix. I don't think gas should be there. Maybe the regulator got fried in the fire?
#4
my son's first car.
edredas
PostPosted: Wed Sep 28, 2016 9:15 am    Post subject: Reply with quote
I thought that was what you were saying...
Yes, that regulator is toast...
jvandyke
PostPosted: Wed Sep 28, 2016 10:31 am    Post subject: Reply with quote
That's what I was thinking. Okay, off to throw up a wanted ad. New ones are pretty dear it seems.
my son's first car.
PostPosted: Thu Sep 29, 2016 1:07 am    Post subject: Reply with quote
Regulator, damper.
A bit spendy, but I wouldn't go used. This might have started your fire.
jvandyke
PostPosted: Thu Sep 29, 2016 11:18 am    Post subject: Reply with quote
ah, good point!
I got one off ebay already but you're right, probably should have gone new. I will check it out thoroughly.
I might autopsy the bad one, interesting to know what happened, internal melting of something I would think.
We'll probably find more fire damaged easter eggs as we go along.
my son's first car.
