A Question about Fuel Line Internal Diameter
agfisher
PostPosted: Sat Sep 10, 2016 5:45 am    Post subject: A Question about Fuel Line Internal Diameter Reply with quote
This is a question that i have with my ongoing rebuild of my fuel system that is here (http://www.924board.org/viewtopic.php?t=42474).
The fuel line I pulled off of the harness at the rear of the car measures 7mm ID (13mm OD). A lot like this stuff (http://www.germanautoparts.com/productdisplay/51310). This stuff though looks to just be normal reinforced rubber and I was hoping to use something that can deal with today's more modern fuels.
I haven't had great luck finding 30R9 compliant hose in the size that is a direct replacement. Instead I'm finding 5/16 ID hose (7.93mm) that fits my need. Anyone think it's a problem to use the slightly larger size?
1977 924 N/A Martini Edition
agfisher
PostPosted: Sun Sep 25, 2016 1:34 pm    Post subject: Reply with quote
Bump. Anybody got some input on this?
PostPosted: Sun Sep 25, 2016 4:52 pm    Post subject: Reply with quote
metal part of the fuel lines are 6mm ID for return and 8 for feed if i remember correctly.
I had to patch the metal lines as they cracked and used some E85 and fuel safe reinforced hoose. So anything reinforced and fuel safe you use above 6mm ID i think will fine.
brian19600
PostPosted: Sun Sep 25, 2016 8:16 pm    Post subject: Reply with quote
Perhaps send an email to the place you just referenced. See if it is designed for today's fuels. If you run the part number (N202811) thru google, you will get more information, too.
My personal opinion is that if the barbs are designed for 7mm, at what point does the barb not do anything and the strength to hold the hose on is assumed primarily by the hose clamp? I don't know. But it's retaining 70 psi gasoline, so, being wrong can have negative consequences.
agfisher
PostPosted: Sun Sep 25, 2016 11:16 pm    Post subject: Reply with quote
That's a good point. I might get a sample of the 8 and see how close it is. I'll also pave a call to see if I can get the modern fuel sage version. Thanks.
Noahs944
PostPosted: Mon Sep 26, 2016 5:36 am    Post subject: Reply with quote
For the fuel tank to fuel pump hose I used steering pump supply hose, from an American truck dealership known as Peterbilt. It is plentiful & in stock & is sold by the foot for dirt cheap.
Later it occurred to me that VW probably stock the right stuff, but for low pressure supply hose it works for my 78 924 .
