vintageant
Joined: 15 Apr 2016 Posts: 35 Location: Miami, Florida
Posted: Thu Sep 22, 2016 12:41 am Post subject: Gas mileage MPG |
As a 5 month first time 924S owner, I'm curious as to gas mileage expectation for these cars.
Car starts immediately and runs very well. 91k miles.
This past weekend on a >300 mile open road cruise, with AC on the whole time, mpg was 21.6. Around town it's been as low as 14.3, and the average for the 890 miles since I've owned is 17.1 mpg.
Seems low, especially compared to my 2003 Honda Accord with 192k miles, and similar size engine in a heavier car, which has returned 25.6 over the past 90k miles.
Thanks for your input _________________ New first time 1987 924S owner - April 2016
1970 VW 'Peking to Paris Rally' Beetle |
Posted: Thu Sep 22, 2016 1:00 am Post subject: |
Is your tail pipe covered with black soot? _________________ White 87 924S "Ghost"
vintageant
Posted: Thu Sep 22, 2016 1:10 am Post subject: |
No, not really.
If it was running rich, how does one adjust mixture on FI?
I'm an old school carb guy!
Thanks! _________________ New first time 1987 924S owner - April 2016
Posted: Thu Sep 22, 2016 2:58 am Post subject: |
Check 02 sensor for proper operation first. _________________ White 87 924S "Ghost"
vintageant
Posted: Thu Sep 22, 2016 3:10 am Post subject: |
Researching, I found this video:
https://www.youtube.com/watch?v=y1Cgn3dq__c
In addition to your O2 sensor suggestion, Throttle Valve Switch, Reference Sensor/Crank Position Sensor and Temp Sensor are also suggested.
Usually, I'd start with the cheapest. _________________ New first time 1987 924S owner - April 2016
Posted: Thu Sep 22, 2016 3:57 am Post subject: |
In my experience, if the car is idling and running smoothly and the O2 sensor is original equipment, it's the first thing to test. _________________ White 87 924S "Ghost"
vintageant
Posted: Thu Sep 22, 2016 4:03 am Post subject: |
OK, thanks!
Please excuse my ignorance, but how does one test it? Or does one just replace? _________________ New first time 1987 924S owner - April 2016
Posted: Thu Sep 22, 2016 4:21 am Post subject: |
Clarks garage is a site that has helped us all...
http://www.clarks-garage.com/shop-manual/fuel-18.htm
You can use the 3 pole O2 connector on the back of the head (passenger side). _________________ White 87 924S "Ghost"
vintageant
Posted: Thu Sep 22, 2016 4:57 am Post subject: |
Thanks!
There's a three prong male plug, with cap, mounted on the engine hoist bracket at the back of the head. nothing attached. It's the male side of this:
https://www.amazon.com/Bosch-13011-Oxygen-Sensor-Fitment/dp/B000BZG5OY
On the exhaust, I see two sensors. The forward larger has a wire ascending. The smaller, about 2" behind, looks like a wire or tube has been cut off.
Really appreciate your help! _________________ New first time 1987 924S owner - April 2016
Posted: Thu Sep 22, 2016 5:20 am Post subject: |
The 3 prong connector is for the O2 sensor. Correction that connector is empty on my car too.
The tube used to run up to the back of the head. Its purpose was to provide an easy place to check the mixture/emissions pre cat. _________________ White 87 924S "Ghost"
vintageant
Posted: Thu Sep 22, 2016 5:32 am Post subject: |
So if there is nothing plugged into that 3 prong male plug, does that suggest the O2 sensor is disconnected?
I'll have to get the car up on ramps to get underneath and grab the wire attached to the sensor to see where it goes...... _________________ New first time 1987 924S owner - April 2016
Posted: Thu Sep 22, 2016 5:35 am Post subject: |
I just put my car up on the lift and looked, the connector is actually on the other side of the head with the reference mark sensor connections.
vintageant
Posted: Thu Sep 22, 2016 6:10 am Post subject: |
Is it one of the two connectors in a white plastic clip directly behind the aft branch of the intake manifold? _________________ New first time 1987 924S owner - April 2016
Posted: Thu Sep 22, 2016 6:24 am Post subject: |
Yes, but try testing it with the one on the lift point. _________________ White 87 924S "Ghost"
vintageant
Posted: Thu Sep 22, 2016 6:40 am Post subject: |
How could I test that if the sensor in the exhaust is not connected to it? Surely the test is on the female connector?
I believe I'm going to order that new one from Amazon and just replace. I'll figure out if it's the one on the left or right of the photo you posted _________________ New first time 1987 924S owner - April 2016
