ignition wiring
Goto page Previous  1, 2, 3  Next
Ian89C4
PostPosted: Sun Sep 18, 2016 12:43 am    Post subject: Reply with quote
Part number on the 81 distributor should be 0 237 022 019 (Bosch part number)
Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala")
PostPosted: Sun Sep 18, 2016 3:29 am    Post subject: Reply with quote
Until we see a picture of the distributor without the cap, we cannot be sure the previous owner did not convert this car to points.
martrnluke
PostPosted: Sun Sep 18, 2016 4:26 am    Post subject: Reply with quote
thank you guys for your help I uploaded more photos to photobucket.
http://s61.photobucket.com/user/martrnluke/library/
luke marten
PostPosted: Sun Sep 18, 2016 4:53 am    Post subject: Reply with quote
Aftermarket system....
PostPosted: Sun Sep 18, 2016 4:55 am    Post subject: Reply with quote
Ian89C4
PostPosted: Sun Sep 18, 2016 5:30 am    Post subject: Reply with quote
Never seen internals on a dizzy like that..hmmm
Will probably need to source a 3 wire hall sensor dizzy.
The wiring shouldn't be too hard to fix...as long as they left the harness alone.
Ian Edgerly
North Carolina
Current:
martrnluke
PostPosted: Sun Sep 18, 2016 5:49 am    Post subject: Reply with quote
according to Bosch that distributor is for a 1977 924. the wiring looks to be mostly easy except for the distributor wiring, i have a green, white and black wire coming from distributor and the harness is black/red, brown/white and green.
luke marten
PostPosted: Sun Sep 18, 2016 8:40 am    Post subject: Reply with quote
That setup is not Bosch but rather a conversion kit to get rid of points. I tried some similar kits in the 80's mainly in Fiat X 1/9s but never was satisfied with their performance.
PostPosted: Sun Sep 18, 2016 8:48 am    Post subject: Reply with quote
something like this:
http://www.pertronix.com/prod/ig/ignitor/default.aspx
j03k64
PostPosted: Sun Sep 18, 2016 8:49 am    Post subject: Reply with quote
Always good to have photo examples. I've found IMGR to be the most friendly for posting photos here.
I would very cautiously and slowly match your wiring with Ians, confirm it with the wiring diagrams appropriate to your year and preferably test it using an ohms meter (most modern voltmeters have them built in) before you apply voltage to the circuitry. There's a step-by-step test procedure in most Haynes manuals to confirm the ignition system system is wired properly and to specifications. You can test the distributor coil resistance during that test as well from the ICU (not sure if it differs for the hall sensor type, I wouldn't think so as it's testing the pickup coil located below the dizzy).
Ensure that the mount points on the ICU box and chassis are clean as it grounds to that point in the 83+ I believe - it looks good in your photos, but better safe than sorry!
1979 Porsche 924
1980 Porsche 924
PostPosted: Sun Sep 18, 2016 8:54 am    Post subject: Reply with quote
for a 77 924?:
http://www.jegs.com/c/Distributors_Conversion-Kits-Points-to-Electronic/11577/10002/-1?N=1011577&Tab=GROUP&enginetype=4294829849&make=4294828607&model=4294826990&submodel=4294829828&year=4294829809
martrnluke
PostPosted: Sun Sep 18, 2016 8:56 am    Post subject: Reply with quote
The distributor says Bosch and has a part number on it but either way I got it all wired up matching wiring diagram and still no spark
luke marten
PostPosted: Sun Sep 18, 2016 9:04 am    Post subject: Reply with quote
To post pictures already uploaded to Photobucket, open your album, double click on the picture you want, go to the bottom right of the screen and click to the right of "IMG". You will see "copied". Then come to this board and paste what you copied into your post.
PostPosted: Sun Sep 18, 2016 9:05 am    Post subject: Reply with quote
It is a Bosch distributor but is has been converted with an aftermarket kit and most likely will not function with the stock ignition module.
PostPosted: Sun Sep 18, 2016 9:11 am    Post subject: Reply with quote
You have at least 3 choices:
Obtain a stock distributor, control module, and wiring
Install a new points elimination kit in the existing distributor
Try to figure out how the existing elimination kit is supposed to be wired and hope the wiring attempts so far have not fried it.
Page 2 of 3
