Ian89C4
Posted: Sun Sep 18, 2016 12:43 am Post subject: |
Part number on the 81 distributor should be 0 237 022 019 (Bosch part number) _________________ Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala") |
Posted: Sun Sep 18, 2016 3:29 am Post subject: |
Until we see a picture of the distributor without the cap, we cannot be sure the previous owner did not convert this car to points. _________________ White 87 924S "Ghost"
martrnluke
Joined: 16 Sep 2016 Posts: 11 Location: coldwater michigan
Posted: Sun Sep 18, 2016 4:53 am Post subject: |
Aftermarket system....
Posted: Sun Sep 18, 2016 4:55 am Post subject: |
Ian89C4
Posted: Sun Sep 18, 2016 5:30 am Post subject: |
Never seen internals on a dizzy like that..hmmm
Will probably need to source a 3 wire hall sensor dizzy.
The wiring shouldn't be too hard to fix...as long as they left the harness alone. _________________ Ian Edgerly
North Carolina
Current:
martrnluke
Posted: Sun Sep 18, 2016 5:49 am Post subject: |
according to Bosch that distributor is for a 1977 924. the wiring looks to be mostly easy except for the distributor wiring, i have a green, white and black wire coming from distributor and the harness is black/red, brown/white and green. _________________ luke marten |
Posted: Sun Sep 18, 2016 8:40 am Post subject: |
That setup is not Bosch but rather a conversion kit to get rid of points. I tried some similar kits in the 80's mainly in Fiat X 1/9s but never was satisfied with their performance. _________________ White 87 924S "Ghost"
Posted: Sun Sep 18, 2016 8:48 am Post subject: |
something like this:
http://www.pertronix.com/prod/ig/ignitor/default.aspx
j03k64
Joined: 26 Jul 2010 Posts: 123 Location: Urbana, Ohio
Posted: Sun Sep 18, 2016 8:49 am Post subject: |
Always good to have photo examples. I've found IMGR to be the most friendly for posting photos here.
I would very cautiously and slowly match your wiring with Ians, confirm it with the wiring diagrams appropriate to your year and preferably test it using an ohms meter (most modern voltmeters have them built in) before you apply voltage to the circuitry. There's a step-by-step test procedure in most Haynes manuals to confirm the ignition system system is wired properly and to specifications. You can test the distributor coil resistance during that test as well from the ICU (not sure if it differs for the hall sensor type, I wouldn't think so as it's testing the pickup coil located below the dizzy).
Ensure that the mount points on the ICU box and chassis are clean as it grounds to that point in the 83+ I believe - it looks good in your photos, but better safe than sorry! _________________ 1979 Porsche 924
1980 Porsche 924 |
martrnluke
Posted: Sun Sep 18, 2016 8:56 am Post subject: |
The distributor says Bosch and has a part number on it but either way I got it all wired up matching wiring diagram and still no spark _________________ luke marten |
Posted: Sun Sep 18, 2016 9:04 am Post subject: |
To post pictures already uploaded to Photobucket, open your album, double click on the picture you want, go to the bottom right of the screen and click to the right of "IMG". You will see "copied". Then come to this board and paste what you copied into your post. _________________ White 87 924S "Ghost"
Posted: Sun Sep 18, 2016 9:05 am Post subject: |
| martrnluke wrote: | | The distributor says Bosch and has a part number on it but either way I got it all wired up matching wiring diagram and still no spark |
It is a Bosch distributor but is has been converted with an aftermarket kit and most likely will not function with the stock ignition module. _________________ White 87 924S "Ghost"
Posted: Sun Sep 18, 2016 9:11 am Post subject: |
You have at least 3 choices:
Obtain a stock distributor, control module, and wiring
Install a new points elimination kit in the existing distributor
Try to figure out how the existing elimination kit is supposed to be wired and hope the wiring attempts so far have not fried it. _________________ White 87 924S "Ghost"
