ignition wiring
Goto page 1, 2, 3  Next
martrnluke
PostPosted: Fri Sep 16, 2016 9:25 am    Post subject: ignition wiring Reply with quote
hello guys i am new on here, I just bought a 1981 924 and I know nothing about these cars except that I like em a lot anyways the guy i got it from didn't know anything about it payed 300 bucks for it but the ignition wiring is cut at the ignition control module and at the coil and distributor it has a Bosch distributor and coil both seem to be either after market or from a 1977 927 i cant seem to figure out the wiring at all to get any spark any help would be amazing
luke marten
PostPosted: Fri Sep 16, 2016 11:25 am    Post subject: Reply with quote
Welcome to the board. Please post some pictures of what you have.
KDJones2000
PostPosted: Fri Sep 16, 2016 12:46 pm    Post subject: Reply with quote
First thing I would do is to go out and buy some sentence punctuation.
Answers will start coming after that.
1987 924S SPEC car
Team Toofah Racing
1988 944 Turbo S
PostPosted: Fri Sep 16, 2016 1:00 pm    Post subject: Reply with quote
High road, snap!
martrnluke
PostPosted: Fri Sep 16, 2016 1:58 pm    Post subject: Reply with quote
i didn't come here to be criticized this is a automotive board not an English or punctuation board thanks ill just figure it out on my own
luke marten
PostPosted: Sat Sep 17, 2016 7:21 am    Post subject: Reply with quote
If it has a points style system, ensure the point open when at TDC and check gap.
A multimeter will help to determine if the coil is getting power.
With the points open it should be 12 v
j03k64
PostPosted: Sat Sep 17, 2016 11:39 am    Post subject: Reply with quote
I would strongly recommend getting a Haynes and an assortment of other manuals if you plan to keep the car! It will also help you sort out the ignition issues as they can be extremely daunting unless you have and can read the schematic.
Can you post a few detailed pictures of the damage near the coil and ICU? That may help members here on the board assist you in undoing whatever cutting has occurred to avoid damaging the ignition system or you in the process of fixing it!
1979 Porsche 924
1980 Porsche 924
martrnluke
PostPosted: Sat Sep 17, 2016 12:03 pm    Post subject: Reply with quote
to be honest im not sure how to share photos on here
luke marten
PostPosted: Sat Sep 17, 2016 12:24 pm    Post subject: Reply with quote
Upload them to some place like Photobucket then copy the URL and use the IMG button. Or email them to me and I will post them.
martrnluke
PostPosted: Sat Sep 17, 2016 12:48 pm    Post subject: Reply with quote
http://s61.photobucket.com/user/martrnluke/library/924
luke marten
martrnluke
i hope that works
luke marten
PostPosted: Sat Sep 17, 2016 1:07 pm    Post subject: Reply with quote
Could you pop the distributor cap and post a picture, wondering if it has points and a condenser....
martrnluke
PostPosted: Sat Sep 17, 2016 2:40 pm    Post subject: Reply with quote
I will get to that in the morning, thank you guys.
luke marten
brian19600
PostPosted: Sat Sep 17, 2016 7:49 pm    Post subject: Reply with quote
To my knowledge no US 924 came with points. ROW did for a few years I believe.
Ian89C4
PostPosted: Sun Sep 18, 2016 12:35 am    Post subject: Reply with quote
The 81 is a hall sensor car. You should be able to fix things fairly easily, it looks like there is enough wire left at the cut spots to solder or get them into connectors.
One thing I do see is an odd ignition switch...possibly why the PO couldn't get her started. I once bought a replacement ignition switch like the one I saw in one of your pics with the riveted heat sync on the back and it did not work for the car, I got nothing. Put the old Bosch unit back on that screws into the larger heat sync you will see in one of the pics below and it started right up. let me know if you would like the part number off of it.
Here are the pics I said I would get for you:
This is the general layout of the ignition switch area on the 81
Here are the connectors. Big one is for the ignition switch - the two that are connected are for the idle stabilizer (the box in the next pic). The car can run without the box, but the connectors must be connected, the car will not run if there is no connection between those three wires.
Idle stabilizer (kinda hard to find them)
These three wires go to the hall sensor. You will have to take a look at the wiring schematic to see which color goes where on the actual hall connector. But all three do run down to the ignition switch - see next pic
Wiring order for the ign switch connector:
Here are how the connectors look on the coil. The two green wires connect to a two prong male plug on the negative side of the coil. And the black wire as well as the black and blue wire are crimped together into one connector on the positive side of the coil.
Let me know if there are any other pics you need. Hope these help get things started for you.
Ian
Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala")
Page 1 of 3
