Crank Pulley
MikeJinCO
PostPosted: Wed Sep 14, 2016 6:04 am    Post subject: Crank Pulley Reply with quote
Is the bolt on the crank pulley by chance a left hand thread?
Mike
'67 MG Midget Dp
Kenodog
PostPosted: Wed Sep 14, 2016 6:24 am    Post subject: Reply with quote
Nope. They are usually on very f'n tight though so I can see why you might be wondering.
Me
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
MikeJinCO
PostPosted: Wed Sep 14, 2016 12:34 pm    Post subject: Reply with quote
Thanks, got two pistons out so I will use a block of wood to lock the crank and go after it.
Mike
'67 MG Midget Dp
PostPosted: Thu Sep 15, 2016 12:03 am    Post subject: Reply with quote
Whenever I needed help with that, I'd drive to a local farmer, and borrow his 3/4 inch air wrench. Spun those babies off like nothing. Better than wedging something in the engine if you can find one of these to rent or borrow.
PostPosted: Thu Sep 15, 2016 6:56 am    Post subject: Reply with quote
If desperate you can put a very long spanner on the nut and wedged against the chassis, disconnect coil to prevent starting and hit the starter briefly.
be aware- spanners are heavy and can fly.
MikeJinCO
PostPosted: Thu Sep 15, 2016 7:26 am    Post subject: Reply with quote
It eventually came off with my 1/2" DeWalt electric impact wrench.
Mike
'67 MG Midget Dp
PostPosted: Thu Sep 15, 2016 9:25 am    Post subject: Reply with quote
Flywheel lock and breaker? Goodness.
