parts cleaning
PostPosted: Fri Feb 26, 2016 11:59 am    Post subject: parts cleaning Reply with quote
It's not as perfect as blasting and re-zincing, but it sure is a helluva lot easier, quicker, and cheaper! Very pleased with the results.
Power Tryp
PostPosted: Fri Feb 26, 2016 12:47 pm    Post subject: Reply with quote
Your method also allows you to keep the sensors and plastics attached where a an abrasive and recoat method would require further teardown.
Melanie - 1980 931
NoName - 1980 931 (seeking rebuild)
Green tartan interior, you don't see that on a Civic.
Kenodog
PostPosted: Fri Feb 26, 2016 1:13 pm    Post subject: Reply with quote
Nope. Most definitely would not want to put electrical components in a liquid ultrasonic bath.
Leigh
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
Power Tryp
PostPosted: Fri Feb 26, 2016 1:14 pm    Post subject: Reply with quote
Why not?
Melanie - 1980 931
Kenodog
PostPosted: Fri Feb 26, 2016 1:31 pm    Post subject: Reply with quote
What would happen to a radio if you put it in a bathtub full of solvent ? (Not plugged in of course )
Leigh
1981 931, Sabine
2024 KLX300
2024 KLX140
Power Tryp
PostPosted: Fri Feb 26, 2016 1:39 pm    Post subject: Reply with quote
Depends on how long you had it in there. I assume when it came out and got completely dried off it would be perfectly fine. Much like your cell phone can survive a dunk in the toilet if you get it shut off immediately and open it up to dry out.
But that's an inside item. Automotive electrical sensors are built to handle both extreme temperatures (engine bay) and chemicals (oils, coolants, etc). Obviously I would happily test this if I had a sonic cleaner, alas I do not.
Maybe Dan will oblige us with some science?
Melanie - 1980 931
Kenodog
PostPosted: Fri Feb 26, 2016 1:51 pm    Post subject: Reply with quote
They are designed to be "resistant" to moisture and oils, not soaked in and the hit with ultrasonic waves. Now they are 30+ years old and the plastic (which was shit even back in the day) is even harder and more brittle, i.e. less likely to seal, than it was back in the age of disco when is was run off the Bosch line in W. Germany.
For the 20 seconds it takes to remove them from the housing I thinks it's time well spent.
Leigh
1981 931, Sabine
2024 KLX300
2024 KLX140
Power Tryp
PostPosted: Fri Feb 26, 2016 1:54 pm    Post subject: Reply with quote
You've definitely got a point about the shitty plastic. I'd say it's kind of a moot point without testing it and it wasn't really a tech tip, just a general observation made on the whole.
Melanie - 1980 931
PostPosted: Fri Feb 26, 2016 11:13 pm    Post subject: Reply with quote
The plastics on these items all came out just fine. I am currently doing a batch of cold start valves, and have done this in the past as well. I would not put a circuit board in there, but any of the sensors in the engine bay should be just fine.
agfisher
PostPosted: Wed Mar 23, 2016 3:17 am    Post subject: Reply with quote
That unit is on sale right now...
http://www.harborfreight.com/25-liter-ultrasonic-cleaner-95563.html?ccdenc=eyJjb2RlIjoiMTkzNDM0MDciLCJza3UiOiI5NTU2MyIsImlzIjoiNjkuOTkiLCJwcm9kdWN0X2lk%0D%0AIjoiMzIyNyJ9%0D%0A&utm_medium=email&utm_campaign=1216a&utm_source=1013&cid=mEmail_s1013_c1216a#pr-header-back-to-top-link
1977 924 N/A Martini Edition
agfisher
PostPosted: Mon Sep 12, 2016 11:20 pm    Post subject: Reply with quote
How do you think this stuff will work with the Ultrasonic Cleaner http://www.homedepot.com/p/Evapo-Rust-1-gal-Safe-Rust-Remover-ER012/206639586
Still haven't found the WD-40 stuff yet.
UPDATE: Ignore this, found some at local Lowes!
hdrider19
PostPosted: Tue Sep 13, 2016 1:01 pm    Post subject: Reply with quote
My choice for cleaning. Whitewall tire cleaner and a garden hose
87 924S
agfisher
PostPosted: Thu Sep 22, 2016 12:25 am    Post subject: Reply with quote
What length cycle do you use for this thing using the WD-40 stuff?
Noahs944
PostPosted: Thu Sep 22, 2016 1:49 am    Post subject: Reply with quote
This is excellent in a container for about 2 days. Just remember to rinse then dry then lube or paint very shortly after.
