early 924 4 speed to 5 speed swap questions...
JaySilver
PostPosted: Sat Aug 27, 2016 12:29 pm    Post subject: early 924 4 speed to 5 speed swap questions... Reply with quote
Hey everyone,
I'm new here, so take it easy on me. Some friends and I just picked up a 77 Porsche 924 that has been racing in 24 Hours of LeMons.
it's got a 4 speed in it right now and I have the opportunity to pick up a 5 speed from a 944...
Do I need to swap out the torque tube to a 924s?
Any other pointers or things to look out for?
Thanks in advance. This site looks like there's a lot of knowledgable folks on it.
Hope they're kind to noobs.
I'm a 924 newbie...be kind.
Glemon
PostPosted: Mon Aug 29, 2016 1:57 pm    Post subject: Reply with quote
There is some information on swaps both on the technical and FAQ sections of this site. A quick look on my part, not sure if it will answer all of your questions, but it is a start.
I am a relative Newby here too, so I don't have a lot of knowledge about the specific questions.
88 924S
68 TR250
02 IS300
Horizonblue
PostPosted: Mon Aug 29, 2016 3:16 pm    Post subject: Reply with quote
I have replaced the 4 speed with a 5 speed in my 1976 car. I found an original 924 5 speed (016 model). I had to make a dent in the fuel tank with a hammer, otherwise the gearbox had zero clearance to the fuel tank.
I believe that the 944 gearbox can bolt right up to the 924 torque tube, but the prop shaft diameter on the 924 and 944 are not the same......
Euro 924, 1976
"If you can't fix it, don't break it"
/P.G. Andersen
PostPosted: Mon Aug 29, 2016 3:36 pm    Post subject: Reply with quote
If you are after performance the 924 5spd is a better choice, the 944 will have similar ratios on 1-4 plus another gear. the 924 is much closer and have 5 gears in almost the same range as the 4 speed. If i remember correctly..
Horizonblue
PostPosted: Mon Aug 29, 2016 3:46 pm    Post subject: Reply with quote
You are right on that, Cédric. RPM's in 5th gear (on the 016 5sp 924 box) are not much lower than 4th on the 4sp box.
Euro 924, 1976
/P.G. Andersen
PostPosted: Mon Aug 29, 2016 9:13 pm    Post subject: Reply with quote
But acceleration is much better, I have numbers on it from the track logs if anyone is interested. Helped a friend do the conversion on his n/a and it gave some significant performance on the straight sections of the track.
nickthompson
PostPosted: Tue Aug 30, 2016 8:22 am    Post subject: Reply with quote
I have ano 81 924 5 speed. I think I can ship it via Greyhound. If you're interested let me know.
