Seized shoes
Wobblydriver
PostPosted: Mon Aug 08, 2016 6:32 pm    Post subject: Seized shoes Reply with quote
Suggestions please. This problem is on an 1984 model. Here are the facts so far. BOTH rear drums are seized solid. It has been parked unused for 10 years, (yes ten). Hand brake OFF, IN gear. It is now up on axle stands. The drums won't turn AT ALL! I've sprayed it regularly with penetrating oil. I've tried to slacken the adjusters, they're seized too. I've had the castle nuts off, the drums are that tight they came off easily. The drum puller just pushed the drive shafts out. I've tapped them with a hammer but I'm cautious of hitting them too hard. What else can I do?
I Know the Voices aren't real, but boy! They come up with some good ideas!
MikesCoupeGT
PostPosted: Mon Aug 08, 2016 8:50 pm    Post subject: Reply with quote
Wobbly;
I wouldn't be too concerned about using the Rural technology on those rear drums, they can take quite a hit. I would heat them a little, not too much though because of the brake fluid and lines that are around it. Then take the hammer to them.
I know that my drums were a tight fit when I first removed them to rebuild the rear brakes on my car. They will come off.
Regards;
Cheers;
MikesCoupeGT
'76 924
'83 944
''19 Elantra GT N-Line
PostPosted: Mon Aug 08, 2016 9:44 pm    Post subject: Reply with quote
Take a bigger hammer, you should change the drums anyway, so damage shouldn't matter
PostPosted: Tue Aug 09, 2016 1:30 am    Post subject: Reply with quote
From what I've read I believe backing off the adjusters is the key to getting the drums off.. I'd therefore concentrate on them first..
80 Turbo - Slightly Modified
dubrict
PostPosted: Tue Aug 09, 2016 2:42 pm    Post subject: Reply with quote
If it was me, I wouldn't even have the patience to post here about it... I would have grabbed a REALLY big hammer and started destroying long ago.
If the car's been sitting 10 years, it safe to assume you need to replace anything a hammer can break back there.. drums, shoes, bearings, and maybe even brake lines if you're clumsy enough, are all stupidly cheap on this car anyway
1979 924 NA
2009 Chevy Impala
2005 Dodge Dakota
Mike9311
PostPosted: Tue Aug 09, 2016 10:56 pm    Post subject: Reply with quote
+1....I awake to ground hog day. This just happened a few weeks ago on this board
1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
1982 931 wana-be GTR race car
POORscheMAN
PostPosted: Wed Aug 10, 2016 1:04 am    Post subject: Reply with quote
Just put the wheels back on and drag the whole car with a truck until they pop free.
I've always had good luck with that method.
Audi 5K Throttle Body - 10:1 comp
Stage 1 Cam -MSD coil- Crane XR700 ignition - Headers
260# springs -26mm rear TBars-
poly bushings -Weltmeister sway bars
1980 924 N/A -- stock
1982 931
1988 944
1994 968 M030
