Wobblydriver
Posted: Mon Jul 18, 2016 10:12 pm Post subject: Totally seized rear drum. |
HELP!!!
I have a neglected 924 with seriously seized rear drums. Both sides are locked solid. A drum puller just pushes the drive shafts out. She's been parked up hand brake OFF, in gear for years. How do I get the drum off to clean everything out? _________________ I Know the Voices aren't real, but boy! They come up with some good ideas! |
Mike9311
Posted: Mon Jul 18, 2016 10:32 pm Post subject: Re: Totally seized rear drum. |
| Wobblydriver wrote: | HELP!!!
I have a neglected 924 with seriously seized rear drums. Both sides are locked solid. A drum puller just pushes the drive shafts out. She's been parked up hand brake OFF, in gear for years. How do I get the drum off to clean everything out? |
1st just start tapping/beating the drum from the sides with a rubber mallet to try and loosen things _________________ 1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
Wobblydriver
Posted: Mon Jul 18, 2016 11:57 pm Post subject: Seized drums. |
Ive tried hitting it with assorted hammers. Nothing happening! Drum doesn't even spin. I'm now at the point where I just want to smash them to get them off! Would heating it with a hand held butane torch help? _________________ I Know the Voices aren't real, but boy! They come up with some good ideas! |
agfisher
Joined: 09 May 2007 Posts: 484 Location: West Hartford, CT
Posted: Tue Jul 19, 2016 12:41 am Post subject: |
I had the same issue. What I need to do was get behind the drum and back off the adjustment screw to bring the pads in. Once the adjustment screw is loosened up bang it with the mallet. That's what worked for me.
Adam _________________ 1977 924 N/A Martini Edition |
Defender405
Joined: 13 Feb 2015 Posts: 60 Location: Des Moines, IA
Posted: Tue Jul 19, 2016 1:10 am Post subject: |
You probably can't get it hot enough with a butane torch to really accomplish anything. I had this happen on an MG once, I had to futz with the adjustment bolt assembly and get it backed out all of the way. Once I got that done I was able to pry from the inside and get the shoes loose enough that the hammer worked to pop it loose. Liberal use of penetrating oil helped too. From my experience the drums can be very difficult to remove on a 924 under good conditions. _________________ Its only money, you can always get more.
1979 924 N/A
1975 MGB
1991 Infiniti M30
1987 300ZX Turbo |
Wobblydriver
Posted: Tue Jul 19, 2016 5:45 am Post subject: Seized drums |
Thanks. I'll spend a couple of days attacking it with penetrating oil and give it another try. _________________ I Know the Voices aren't real, but boy! They come up with some good ideas! |
Posted: Tue Jul 19, 2016 11:09 am Post subject: |
Loosen the adjusters, remove inspection plugs on the back of the backing plates and pry the shoes away from the drums. _________________ White 87 924S "Ghost"
Tiny
Posted: Fri Jul 22, 2016 6:36 am Post subject: |
I was flummoxed with this once before, burning and bashing it repeatedly for a good afternoon until I realised and completely backed off the adjusters. Hey Presto. Drum fell off. _________________ *****1981 - 924 - Auto - London, UK****** |
