Cam belt cover refit
RobertN
PostPosted: Sun Jul 17, 2016 8:11 am    Post subject: Cam belt cover refit Reply with quote
Anyone know how to refit the cam belt cover. I wrestled with it to remove it to change cam belt and fix stat housing leak.
Driving me crazy!!
Robert.
Porsche 924 N/A 1984.
Electrical Engineering Sales to Control panel builders.
PostPosted: Sun Jul 17, 2016 8:25 am    Post subject: Reply with quote
If it's driving you crazy, you're doing it right...you just need to suffer a bit longer.
brian19600
PostPosted: Sun Jul 17, 2016 9:57 am    Post subject: Reply with quote
When I bought mine, the cover was off. Is there a trick to getting it on?
Glemon
PostPosted: Sun Jul 17, 2016 1:21 pm    Post subject: Reply with quote
There may be a trick I am not aware of, but as I recall there was a bit of trial and error of pushing and pulling and trying to slip it on from different angles, some finesse and some brute force involved, but it should slide back into place without bending or gouging anything too bad.
Be patient and persistent, don't recall any sledge hammers or two foot pry bars needed to force it back. Good Luck!
88 924S
68 TR250
02 IS300
PostPosted: Sun Jul 17, 2016 4:41 pm    Post subject: Reply with quote
You can trim of some edges and it will be a much easier job
PostPosted: Sun Jul 17, 2016 4:54 pm    Post subject: Reply with quote
Thats about right
You can actually do a nasty cut to the timing belt if you're insistant.
Either trim it to fit or remove everything in front of it to install it.
