chris79
Posted: Mon Jul 11, 2016 4:40 am Post subject: Air conditioned |
In my 924 I have not original air conditioned system.
This picture is the exact point for charge the system ? Above the accumulator? There is a thread and if I remove the screw inside there is a transparent surface. This can be the valve for charge ?
http://plus.google.com/photos/photo/106493825386573398385/6305765586321080274?icm=false&authkey=CMPkhrihqqu9Rg _________________ Porsche 924 2.0 na 125hp (1979) euro
Alfa Romeo Spider "Duetto" 1.6 104hp (1986) euro |
Posted: Mon Jul 11, 2016 6:07 am Post subject: |
That's the bubbles visiting thing. You charge it before the compressor. Go to a clima garage. _________________ Supercharger and EFI kits
TJC
Joined: 04 Apr 2010 Posts: 828 Location: Northwestern-ish Arizona, USA
No! The transparent window is the sight glass to monitor the flow of Freon. The system gets charged through a threaded port with a Schrader valve in it on the low pressure (suction) side of the system. If you are not familiar with charging an A/C system I strongly suggest you take it to someone who is or educate yourself thoroughly before you do it yourself. I'm not trying to dissuade you from working on your own car just advocating safety as an incorrect move could have serious effects. Also, if the system has been empty for awhile it should be evacuated first and left in a vacuum for at least 1/2 hour to determine if there are any leaks otherwise you're just wasting your time.
Good Luck! _________________ '95 BMW 318i/5 ..."Pearl"
'04 BMW X3..."Xander"
Still on the Prowl!
www.ttrs1.com |
brian19600
Posted: Mon Jul 11, 2016 6:08 am Post subject: |
The purpose of the sight glass is to see if there are bubbles. If there are, then the system needs more freon.
The connection may be at the back end of the compressor. You will have a high and low pressure connection.
LOL, it looks like 3 of us all answered at the same time. _________________ 78 924 |
chris79
Posted: Mon Jul 11, 2016 8:06 am Post subject: |
I read that system must have a low and high pressure valve, but I don't found it.
Compressor have two pipes, one that go directly in cockpit, one that go to coolant system, then to accumulator and to cockpit.
There are no others valves. _________________ Porsche 924 2.0 na 125hp (1979) euro
brian19600
Posted: Mon Jul 11, 2016 11:11 am Post subject: |
Yes, and they may/should have plastic or metal caps covering them. You going to have to search around on the various hose fittings and find them. They are there in the engine compartment somewhere! Mine were on the hoses that connected onto the compressor. They shouldn't be hard to find. _________________ 78 924 |
chris79
Posted: Tue Jul 12, 2016 4:52 am Post subject: |
I check system and there are no valves! How it's possibile? _________________ Porsche 924 2.0 na 125hp (1979) euro
you're blind  _________________ Supercharger and EFI kits
chris79
Posted: Tue Jul 12, 2016 5:06 am Post subject: |
Not, I followed path of all pipes and I don't found valves. _________________ Porsche 924 2.0 na 125hp (1979) euro
TJC
chris79
Posted: Tue Jul 12, 2016 5:56 am Post subject: |
The pipe from cooling system to accumulator go in the front of car, ir may be that I don't look well this zone. _________________ Porsche 924 2.0 na 125hp (1979) euro
brian19600
Posted: Tue Jul 12, 2016 6:56 am Post subject: |
Here is a couple of drawings from the factory manual showing what the valves look like.
[/img]
Here they are on the back end of the compressor. They should be in a place where the gauges and hoses can be connected on for charging. I've seen some of the newer accumulators also having a low pressure charging port on the top, but that would be very easy to see. _________________ 78 924 |
chris79
Posted: Tue Jul 12, 2016 3:14 pm Post subject: |
Ah ok then I found them, there are two caps on compressor, these probably are the valves.
I need even of compressor belt that is broken, where can I find a personalized belt ? _________________ Porsche 924 2.0 na 125hp (1979) euro
chris79
Posted: Thu Jul 14, 2016 3:21 pm Post subject: |
However I thought that instead of restoring the air conditioning , I could remove the compressor and make room for a turbine and then start turbo conversion 😃 _________________ Porsche 924 2.0 na 125hp (1979) euro
Posted: Thu Jul 14, 2016 3:56 pm Post subject: |
What a way of thinking...
You can probably keep the value of your 924 a bit higher if you dont destroy the AC and find a different place for the turbo. _________________ Supercharger and EFI kits
