curtisr
Joined: 07 Apr 2012 Posts: 98 Location: Kingston, Ontario, Canada
Posted: Fri Jul 08, 2016 9:21 am Post subject: Compression test numbers? |
I'm about to embark on testing the compression in my 1987 924s and am wondering what kind of numbers I should see. The 944 workshop manual (which is what is returned when I search online) suggests that any value of 145 psi or more is what I should expect. Knowing the compression ratio is different for the 924s is it reasonable to see such numbers or should I be looking for something else?
Thanks everyone. _________________ World's worst welder. |
edredas
Posted: Fri Jul 08, 2016 11:10 am Post subject: |
Yes! Anything over 145 psi is fine for a 924S. My 1987 924S engine right before I pulled it put out to swap in the 951 engine was 175, 182, 180, 175. That said, I wouldn't expect those numbers since that engine was modified, but if you are only getting 145 psi it would imply a worn engine.
I hope that helps! _________________ '84 944 -White, Brown interior
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver |
curtisr
Posted: Fri Jul 08, 2016 9:41 pm Post subject: |
Thank you! _________________ World's worst welder. |
