Borken
Joined: 23 May 2015 Posts: 5 Location: Falkenberg, Sweden
Posted: Thu Jun 16, 2016 12:26 am Post subject: Did i burn the cable |
Hi!
Clever me tried to swap my old rev counter to a fresh one from a 924S. I did not have the same terminals as the old one but one was marked + and the one under it gn (ground?). I tried the signal cable on the other terminals but with no success. I swapped the cables back to to the old rev counter but itīs just as dead as the new one
I no longer have any voltage on the black lead. Of course some of the other meters where dead too, same supply cable i suppose.
The black cable is not fused.
Is my supply cable fried and where do i start looking?
I seems totally intact the little bit that is visible. No fuse box connectors is blackened.
Help! _________________ Jack of all trades, master of none |
daniel
Joined: 18 Jun 2009 Posts: 686 Location: Sydney, Australia
Posted: Thu Jun 16, 2016 3:08 pm Post subject: |
From memory -
Black is signal wire
Brown is earth
Pink is switched 12v _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
edredas
Posted: Thu Jun 16, 2016 3:32 pm Post subject: |
On the 924S the black wire comes from terminal 87 of the fuel pump relay. If you need to trace the wire, it goes through the firewall and to the 9 pin connector behind the brake booster.
I hope that helps! _________________ '84 944 -White, Brown interior
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver |
Borken
Posted: Fri Jun 17, 2016 12:58 am Post subject: |
Ok, thanks for the replys!
The car is a 924 N/A 1981
The black wire is fed from 15 and is positive and goes via the main instrument.
Perhaps something burned out in the instrument?
But my fuse box was tampered with so i will install a better one and go from there. _________________ Jack of all trades, master of none |
edredas
Posted: Fri Jun 17, 2016 4:31 am Post subject: |
My mistake, I thought you had a 924S and were just swapping another tach in and trying to trace the power wire back to the source.
I'm not sure how you are connecting the 924S tach in the early car, but it should be mentioned that the wiring is of course different colors. So trying to match green wire to black wire will end up a mess. The black wire is positive for this tach and green is signal.
As for the ground, the 924S tach will not work without the ground plugged in for the bulbs on the back of the case.
Shurick
Joined: 15 May 2005 Posts: 524 Location: Russia, Moscow.
Posted: Fri Jun 17, 2016 5:10 am Post subject: |
I may be wrong, but 924 tach is different from 924S/944. 924 tach counts pulses from coil negative terminal and 924S is voltage-driven from ECU unit. _________________ WBR, Shurick
'86 924S -- R.I.P.
https://www.instagram.com/ru_pacecar/ |
edredas
Posted: Fri Jun 17, 2016 5:28 am Post subject: |
The 924S/944 DME sends pulses to the coil and the tach just reads those. These pulses aren't any different than the early cars. A guy once asked me to make his 924S look like an early 924 inside so I swapped the speedo, tach, clock, and oil pressure gauge over from a '77 924. I only had verify the wiring and everything worked perfectly! _________________ '84 944 -White, Brown interior
Ian89C4
Posted: Fri Jun 17, 2016 6:34 am Post subject: |
If I remember correctly
924 (non S)
Green - Signal wire from negative side of coil (should be a two wired connector at the coil
Black - 12V
Brown - Ground
I haven't messed with a stock wiring loom in a few years, so where the power comes from I don't exactly recall.
Check you grounds behind the fuse box. There are two "wheels" of them attached the sheet metal behind the fuse box. They are usually very corroded if they haven't been tended to in 30+ years. That may be where your problem is.
Good luck,
Ian _________________ Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala") |
Borken
Posted: Sat Jun 18, 2016 1:27 am Post subject: |
Yes that wiring was correct!
I swapped the fuse box and now i believe my electric system works 100%
/janne _________________ Jack of all trades, master of none |
Ian89C4
Posted: Sat Jun 18, 2016 12:04 pm Post subject: |
Great! _________________ Ian Edgerly
North Carolina
Current:
