Tanso
Posted: Thu Nov 05, 2015 3:47 am Post subject: |
UPDATE
We continue with the project
Installing the front suspension back together.
A couple of cooling hoses behind the engine and the radiator.
Installing the exhaust system.
The rubber mountings are kinda in bad shape.
New.
Dont laugh at the rear exhaust pipe! It's just temporary!
Now we adjust the camshaft timing.
We measure so that the intake and exhaust lobes are exactly equal in opposite directions.
Then we make a small mark so we can get back to the same position.
We have decked the block and a different camshaft so we can't get the timing 100% correct so we adjust the timing to be a little "earlier" so that we gain some power.
Continuing with the fuel system. We have to test it's function first.
Mounting the k jet ironic unit.
New fuel filter.
To test the fuel system we first need to jump the fuelpump so that it pumps fuel when we turn on the power.
One bottle under every injector.
Turning on the power and lifting up this thing on the k jetronic.
We want the fuel to be closely the same on each cylinder and that the injector doesn't spray in weird pattern.
One of the injectors turned out to spray in a strange pattern so we ordered 4 new ones! _________________ Our 1983 Porsche 924 project: http://www.924board.org/viewtopic.php?p=364034#364034
Power Tryp
Joined: 16 Apr 2009 Posts: 435 Location: Calgary, Alberta
Posted: Thu Nov 05, 2015 4:05 am Post subject: |
Simply fantastic. I can't wait till you have this running and can enjoy it. _________________ Melanie - 1980 931
NoName - 1980 931 (seeking rebuild)
Green tartan interior, you don't see that on a Civic. |
Tanso
Posted: Thu Nov 05, 2015 5:13 am Post subject: |
| Power Tryp wrote: | | Simply fantastic. I can't wait till you have this running and can enjoy it. |
We are working slow but our goal is to have it up and running before december!! _________________ Our 1983 Porsche 924 project: http://www.924board.org/viewtopic.php?p=364034#364034 |
snakoil
Joined: 09 Feb 2010 Posts: 362 Location: Montreal, Canada
Posted: Thu Nov 05, 2015 6:25 am Post subject: |
Are you a science teacher or running a meth lab to be having 4 of these around?
 _________________ 1979 924 NA |
Tanso
Posted: Thu Nov 05, 2015 6:57 am Post subject: |
| snakoil wrote: | Are you a science teacher or running a meth lab to be having 4 of these around?
Yes I have a small lab in the basement so thats why I have these tubes It's quite popular here in Sweden.
Posted: Thu Nov 05, 2015 5:32 pm Post subject: |
What are you brewing?
I like the fact that you renew things on your 924 but i would have refreshed the struts at the same time and remove the rust and coat for protection the wheel wells before installing the new stuff on the car. _________________ Supercharger and EFI kits
Tanso
Posted: Fri Nov 06, 2015 2:41 am Post subject: |
| morghen wrote: | What are you brewing?
I like the fact that you renew things on your 924 but i would have refreshed the struts at the same time and remove the rust and coat for protection the wheel wells before installing the new stuff on the car. |
Blue crystals
Well we take everything in steps. The dampers is probably bad after all these years and when we replace them we will freshen everything up! _________________ Our 1983 Porsche 924 project: http://www.924board.org/viewtopic.php?p=364034#364034 |
Tanso
Posted: Mon Nov 16, 2015 6:00 am Post subject: |
UPDATE
We bought a used MSD unit that we are going to install now!
First we install a MSD coil
We cut the green and purple wire.
Then we cut the green wire going to the distributor.
The green wire has a inner and outer wire.
The green wire from MSD goes to the inner wire and the purple one goes to the outer wire.
Orange from MSD to + and black to -.
The MSD "on/off" wire go to the original green/white wire from the stock unit.
We test the MSD before final install.
We put in a spark plug and rotate the distributor.
We have spark! So it works perfectly.
Now we mount it permanently.
Then its installed!
We also installed a oil temp gauge! We put the sender in the upper oil plug.
Removing the useless clock.
Done
Tanso
Posted: Mon Apr 25, 2016 5:55 am Post subject: |
UPDATE
Okay the brake discs looks really terrible so we decided to change them too.
Looks really terrible...
Quick black paint!
Better
uncledoodoo
Posted: Tue Apr 26, 2016 1:01 am Post subject: |
Any videos of this car running after all the work? How does it run??
Fantastic build thread! |
Tanso
Posted: Tue Apr 26, 2016 6:23 am Post subject: |
| uncledoodoo wrote: | Any videos of this car running after all the work? How does it run??
Great that you like the thread We have not started it yet We have actually ordered a weber 45 carb kit from Ideola  _________________ Our 1983 Porsche 924 project: http://www.924board.org/viewtopic.php?p=364034#364034 |
Tanso
Posted: Tue Apr 26, 2016 6:37 am Post subject: |
UPDATE
Soon we will be able to start our engine for the first time! But we will not be using the mechanical injection. We are going to install a weber 45 kit instead
But in the mean time something else has happened! We got a free Porsche 924!! When we first heard that we could get it for free we thought that it would be a old rusty wagon.
This is how it looked.
We got a little chocked! The chassis is in good condition with barely any rust. And its a 1977 model! It looks good on the underside too!
The engine is complete and works according to the last owner.
But why we got it for free? Take a look inside...
The instruments has burned down and the interior is covered in ashes. Really sad because the chassis is in such a good condition. We thought about using this as a spare parts car, taking the engine and then sending it to the scrap yard...
But we decided to remove everything to see how bad it really is. If we could get this to work we can fix it and sell it to finance our main project
Lots of aftermarket stereo parts that we believe to be the culprit!
We have an old ignition switch from the white 924 that we scrapped. We attach that one and fix all the burnt cables. We don't know where anything should go but for now we just take the cables that we need to start the engine!
Before start we do a regular service. Oil, filters and coolant. Fitting a thermostat too!
After some runs with the starter it runs!! Video from the first start below:
https://www.youtube.com/embed/UuzVg0JH1wU
At this point we have hope about the car and it looks that we can save this car and sell it.
2 questions. There are a ton of cables going into the ignition switch and they are not marked so we don't know where they should go!
And the fuel pump relay gets really hot and smoke comes out of it. We have another relay but it doesn't have a fuse on it like the one in the car... Hmm? _________________ Our 1983 Porsche 924 project: http://www.924board.org/viewtopic.php?p=364034#364034 |
Anders924
Posted: Tue Nov 22, 2016 5:39 pm Post subject: :) |
Been great following you guys project! Any update coming soon? |
