Ign Distributor hitting hood?
Noahs944
PostPosted: Thu Apr 21, 2016 12:19 am    Post subject: Ign Distributor hitting hood? Reply with quote
The Ign distributer is hitting the hood when cornering. Is this common? Does it represent a bad engine mount? I have already moved the hood rearward as much as possible & hammered the seam away from the distributor. But it's still contacting the Beru distributor which has lead to a broken rotor. I'm inclined to raise the hood at the back but the lines match up nicely (looks like proper fitment). Thoughts? I can't lower the engine mounts can I?
PostPosted: Thu Apr 21, 2016 12:26 am    Post subject: Reply with quote
Wrong engine mount? Wrong dizzy? Wrong dizzy instalation...is it fully home pushed into the head? i think it should, otherwise oil would come out...but do a check.
I'd expect if an engine mount failed the engine going lower not higher.
Dont do any mods, there is no way with original parts that the dizzy makes contact to anything.
PostPosted: Thu Apr 21, 2016 1:57 am    Post subject: Reply with quote
Except if the housing is installed wrong. . .remember it has two sets of mounting holes.
Noahs944
PostPosted: Fri Apr 22, 2016 12:49 pm    Post subject: Reply with quote
Rasta, I think you probably nailed it buddy. Many many thanks.
Noahs944
PostPosted: Sat Apr 23, 2016 1:13 pm    Post subject: Reply with quote
IT WORKED IT WORKED!!!
PostPosted: Sat Apr 23, 2016 2:19 pm    Post subject: Reply with quote
durrrrr
