Snailshell trans 2nd gear grinding
Bockscar
PostPosted: Mon Apr 18, 2016 10:53 am    Post subject: Snailshell trans 2nd gear grinding Reply with quote
It's a 1979 snailshell with < 70k miles on it. Just replaced the shift coupling and put new trans oil in it. Took it for a drive around the block and 2nd gear grinds like nobody's business. I found it difficult getting into 1st gear, but it didn't grind like 2nd gear did.
Is this a tell-tale sign that the trans is a goner?
Brian
'79 924 - Restoration In Progress
'81 924 Turbo w/EFI - Scrapped
PostPosted: Mon Apr 18, 2016 4:02 pm    Post subject: Reply with quote
maybe you installed the coupling wrongly?
PostPosted: Mon Apr 18, 2016 7:27 pm    Post subject: Reply with quote
What oil did you put in? It can make a significant difference.
kevingross
PostPosted: Tue Apr 19, 2016 2:14 am    Post subject: Reply with quote
Did it grind before you changed the coupler? I'd start by checking the coupler set-up.
Kevin
Catellus Engineering, Inc.
http://www.catellusengineering.com/
catelluseng@gmail.com
PostPosted: Tue Apr 19, 2016 5:22 am    Post subject: Reply with quote
+1 to above. Shift extra deliberately, making sure you aren't getting a piece of reverse on your way to second.
Also, what is the condition of the clutch pedal mechanism and clutch hydraulics? Are you touching the floor with the clutch pedal between shifts?
Bockscar
PostPosted: Tue Apr 19, 2016 6:10 am    Post subject: Reply with quote
I'm afraid I'd bust it if I shifted deliberately..
The clutch is a cable (non turbo) and the pedal squeaks a bit. Is the cable adjustable?
Brian
Bockscar
PostPosted: Tue Apr 19, 2016 6:11 am    Post subject: Reply with quote
Update: Went for a drive. I press the clutch to the floor and if I'm careful, I can shift from 1st to 2nd without grinding. However, shifting from 2nd to 1st is impossible without grinding, even at stops.
Brian
kevingross
PostPosted: Wed Apr 20, 2016 1:53 am    Post subject: Reply with quote
Brian, if the grinding is an issue only when selecting second gear, the problem is almost certainly due to a severely worn synchro for that gear.
Let me know if you need help with a rebuild.
Kevin
Bockscar
PostPosted: Wed Apr 20, 2016 12:07 pm    Post subject: Reply with quote
I was mistaken with my initial observation - it grinds when shifting into 1st gear at any speed other than stopped.
Brian
PostPosted: Wed Apr 20, 2016 12:51 pm    Post subject: Reply with quote
I've never put it in first any other time...
Bockscar
PostPosted: Wed Apr 20, 2016 1:37 pm    Post subject: Reply with quote
Ah, ok fair enough. I occasionally shift my cars into 1st when I'm coasting < 5 mph to a stop sign or light.
2nd gear lugs really hard when I shift above like 10 - 15 mph. I know the engine is running super rich right now so that might be why.
I'd really like for this whole grinding thing be a case of "User Error". I can't test drive it much because the tires are shot and I'm having trouble sourcing new ones.
Brian
PostPosted: Wed Apr 20, 2016 1:39 pm    Post subject: Reply with quote
So is the clutch cable adjusted to spec?
Bockscar
PostPosted: Wed Apr 20, 2016 1:45 pm    Post subject: Reply with quote
Unsure - haven't checked.
I do know that the shift bushing/coupling was replaced and is installed correctly and I replaced the gear oil with Sta-Lube GL5. First time I drove the thing was last weekend.
Brian
