Noahs944
Joined: 08 Dec 2015 Posts: 782 Location: Calgary, Alberta, Canada
Posted: Sat Apr 16, 2016 1:05 am Post subject: HELP!! Fuel pump relay problems! |
Problem: fuel pump relay (for 78 924) p/n # 477 906 059 is no longer available.
Any suggestions? Porsche has the 79 and up ones in country.
I need a relay, what are the options?
Thanks in advance! |
Noahs944
Posted: Sun Apr 17, 2016 12:20 am Post subject: |
| Wow... what a let down. |
Posted: Sun Apr 17, 2016 1:46 am Post subject: |
Ask where you order the parts if they are compatible. They should know.
You can have the old relay rebuilt by an oldschool electronics shop. I have two turbo relays rebuilt. You can also do a hack and use a normal relay but in case of an accident the pump will still run even if the engine dies...thats a hazard. Also if you do this hack as long as the key is turned the pump will run forever regardless if the engine is working or not. I have this on both my cars since original turbo relays are also impossible to find. _________________ Supercharger and EFI kits
sheepdog924
Joined: 03 Dec 2013 Posts: 20 Location: United Kingdom
Noahs944
Posted: Sun Apr 17, 2016 8:56 am Post subject: |
Thanks fo the excellent help! |
brian19600
Posted: Sat Apr 23, 2016 9:11 pm Post subject: |
Yeah I use the same relay. Keep on eye on ebay as the poster suggested. Junkyards, craigslist ads or on this board, people parting out 77-78's. _________________ 78 924 |
