Is my tappet adjustment screw too far out?
JjyKs
PostPosted: Tue Mar 29, 2016 12:32 am    Post subject: Is my tappet adjustment screw too far out? Reply with quote
I put the head back to the car today, and when i started adjusting valve lashes everything went well, except for this one tappet.
My head was machined couple months ago. I'm 99% sure that i didn't mix the tappets witch each other. Is this machine shops fault and what are my options? Is this ok, or should i do something about it?
jason c
PostPosted: Tue Mar 29, 2016 2:03 am    Post subject: Reply with quote
That looks to be right at the limit. You should verify that the screw is fully threaded into the tappet, not just catching by a couple threads. If its fully threaded & as long as its not sticking out it should be OK. However, you should remove it and find a scew with at least one less line so you'll have adjustment. The clearances should be checked hot & things will change with heat & wear.
Its normal to need different screws after head/valve work. As the valves & seats are ground, the valve moves up in the head, effectively lengthening the stem. This makes less clearance between the stem & cam which requires a smaller screw.
Fifty50Plus
PostPosted: Wed Mar 30, 2016 1:41 am    Post subject: Reply with quote
I am in the process of adjusting lifters on a new cam/engine combo and that is too far out in my opinion. The far end of the screw in your photo is not in the threaded portion of the lifter. At best, barely one thread. You should replace it with a screw one mark lower (if it has 3 slashes on the end, replace it with one that has 2 slashes).
1982 924 NA race car - Sold
1981 924 Turbo sold
1982 924 Turbo sold
JjyKs
PostPosted: Wed Mar 30, 2016 3:05 am    Post subject: Reply with quote
Where can i find those screws?
Porsche dealer? Or are these some generic ones used in some VAG car as well?
PostPosted: Wed Mar 30, 2016 3:20 am    Post subject: Reply with quote
They are VAG parts.
From the 924.org link above:
http://www.924.org/parts/parts.htm
different notches for different sizes, see the maintenance manual for application. 1 notch is thinnest, 4 thickest.
046 109453 C - 0 Notch
046 109453 D - 1 Notch
046 109453 E - 2 Notch
046 109453 F - 3 Notch
046 1094533 - 4 Notch
PostPosted: Wed Mar 30, 2016 3:51 am    Post subject: Reply with quote
Thought they were nla
PostPosted: Wed Mar 30, 2016 3:56 am    Post subject: Reply with quote
Wouldn't doubt it.
JjyKs
PostPosted: Wed Mar 30, 2016 4:41 pm    Post subject: Reply with quote
Thanks guys, I found couple shops which seem to still have them in stock (quite pricey considering that it's just a screw, 27€ but if i just couple of them it's not that bad) . Gonna adjust the 3 tappets i still have unadjusted and check if one of them has this same problem. After that i'll order the amount needed.
Another thing i was thinking was grinding down the current screw like 0.15mm or something like that.
PostPosted: Wed Mar 30, 2016 9:16 pm    Post subject: Reply with quote
You need screws with MORE not FEWER hashes on the end. And yes, they are NLA from Porsche, so the only option is finding new old stock or salvaged pieces.
JjyKs
PostPosted: Wed Apr 06, 2016 5:03 pm    Post subject: Reply with quote
I had 1 more screw which got quite far out. I ended up carefully grinding both screws down by 0.2mm. However they were still on the treads on the both sides, and even had 2 turns more before they would've touched the wall so they should've been safe to use. Now they're 4 more turns in so that's good.
PostPosted: Thu Apr 07, 2016 1:21 am    Post subject: Reply with quote
Are you saying you ground the flat? Rolling the dice... that is a hardened surface that takes a lot of abuse. Keep an ear on it.
Fifty50Plus
PostPosted: Thu Apr 07, 2016 12:05 pm    Post subject: Reply with quote
What Rasta said.
1981 924 Turbo sold
1982 924 Turbo sold
JjyKs
PostPosted: Thu Apr 07, 2016 6:38 pm    Post subject: Reply with quote
Hmm, thanks for the warnings. I ground the flat part of the screws, not the tappet itself if it sounded like that. Gotta check them again after a while of driving.
Shouldn't the whole screw be hardened anyways? I used a flat piece of glass and like 3 arcs of fine sandpaper and measured every side of the screw multiple times during the sanding to ground it down symmetrically (it was so hard material that it took like 20 minutes per screw with 600 grid paper. Could this cause some damage to the hardened surface or should it be safe to assume that it's just as hard 0.2mm inside the screw as well?
The shops i found didn't ship to Finland so i'll keep an eye and ear on these two and if it seems like they're wearing down faster than they sould i'll just get the solid tappets with shim plates.
