CAM BELT COVER REMOVAL 924 NA.
Goto page Previous  1, 2
RobertN
PostPosted: Sat Mar 26, 2016 8:30 am    Post subject: Reply with quote
Yes the single line wear mark you can see on the middle of the belt. I assume it wasn't there when fitted, but I may replace it ne way.
Robert.
Porsche 924 N/A 1984.
Electrical Engineering Sales to Control panel builders.
RobertN
PostPosted: Wed Mar 30, 2016 2:41 am    Post subject: Reply with quote
Hi Stefan, do you need a special tensioner pulley wrench to tighten the belt. Mine looks like yours with the two holes as opposed to a tension "nut" shown in the Haynes manual?!
Robert.
PostPosted: Wed Mar 30, 2016 3:13 am    Post subject: Reply with quote
Yup.
There's a "Pin spanner" that fits in there. Its a fairly standard VW/Audi tool.
If you can't get one, you can use a pair of 90 degree circlip pliers in a pinch.
http://www.amazon.com/Zdmak-Pin-Wrench-3212-Audi/dp/B00XN7G7JK
RobertN
PostPosted: Wed Mar 30, 2016 5:01 am    Post subject: Reply with quote
Nice one Stefan.
Cheers
Robert.
PostPosted: Wed Mar 30, 2016 6:24 am    Post subject: Reply with quote
Also:
http://www.sears.com/schwaben-timing-belt-tensioner-adjustment-tool-60-offset/p-00902990000P?prdNo=10&blockNo=10&blockType=G10
PostPosted: Fri Apr 01, 2016 12:26 pm    Post subject: Reply with quote
2 nails inserted in the holes and a screw driver wedged between them works in a pinch.
RobertN
PostPosted: Fri Apr 01, 2016 5:27 pm    Post subject: Reply with quote
Cheers Paul.
As I only need to do it once I think the 2 nails job will do. LOL
Robert.
Page 2 of 2
