Clutch master cylinder replacment
JasonO
PostPosted: Sat Mar 05, 2016 5:32 am    Post subject: Clutch master cylinder replacment Reply with quote
I've noted the clutch master cylinder is weeping slowly (not sure for how long but enough that I topped up the fluid slightly), I'd like to replace soon, and would be great to hear where others would buy one from?.
Asked about in New Zealand but no avail at local part suppliers
Car is a Euro 924 turbo 1980.
PostPosted: Sat Mar 05, 2016 6:20 am    Post subject: Reply with quote
http://www.ebay.com.au/itm/OEM-FTE-Transmission-Input-Trans-Clutch-Master-Cylinder-NEW-for-Porsche-944-924-/361318202490?hash=item54203e3c7a:g:k54AAOSwwPhWi8Ua
http://www.pelicanparts.com/More_Info/477721171.htm?pn=477-721-171
Also these guys list ATe:
http://www.speed.co.nz/
PostPosted: Sat Mar 05, 2016 6:30 am    Post subject: Reply with quote
Strongly recommend replacing both the master and slave cylinders at the same time.
PostPosted: Sat Mar 05, 2016 7:44 am    Post subject: Reply with quote
and the flex hoses while you're in there.
JasonO
PostPosted: Tue Mar 08, 2016 3:12 pm    Post subject: Reply with quote
Ok got it cheers as always,
