Power steering pump
daniel
PostPosted: Mon Mar 07, 2016 2:27 pm    Post subject: Power steering pump Reply with quote
This is related to a 944 S2 but I am guessing the power steering pump is the same.
Pump seems to have stopped working, not leaking just not working at all. I have been told it could be a stuck vane? Is it possible to rebuild these? Seems replacement is about US$200 so is there a cheaper VW alternative perhaps?
1989 944 Cabriolet
PostPosted: Mon Mar 07, 2016 2:33 pm    Post subject: Reply with quote
http://rennbay.com/Power-Steering-Pump-Seal-Kit.html
Rebuild isn't terribly hard to do.
You'll want to replace the reservoir and its in-built filter.
http://rennbay.com/Power-Steering/944-Power-Steering-Reservoir-Filter.html
You may also want to replace the seals in the rack since it will likely need them.
http://rennbay.com/Power-Steering/944-Power-Steering-Rack-Seal-Kit.html
peterld
PostPosted: Mon Mar 07, 2016 4:04 pm    Post subject: Reply with quote
Exactly what Fiat said.
80/81 932/8 ROW
daniel
PostPosted: Tue Mar 08, 2016 9:31 am    Post subject: Reply with quote
Thankyou for the information,
Daniel
1989 944 Cabriolet
