What are my 924 caliper options?
Goto page Previous  1, 2
rallyimp
PostPosted: Mon Feb 29, 2016 8:42 am    Post subject: Reply with quote
daniel wrote:
Calipers from a early 90's A4 audi (also used on a golf GTi?) will bolt right up, Hawk also has some excellent pads for them. This allows you to keep your 4 lug setup
Hi Daniel, I'm running a 4 lug set up could you give me some more details about the Audi option? does it give you an option to run vented discs and if so what discs do you use
thanks
Regards
Chris Valentine
1981 Porsche 924 N/a Historic Rally Car
https://sites.google.com/site/valeracing09/home/porsche-924
daniel
PostPosted: Mon Feb 29, 2016 10:27 am    Post subject: Reply with quote
No you can't use the vented rotors from the Audi as they are for a FWD setup. I don't know the exact part number of the calipers, however if you go to your local wreckers and have a look around I don't think they will be hard to identify. They are cast iron and are marked with Lucas and VW Audi
1989 944 Cabriolet
Topls82
PostPosted: Sat Nov 05, 2022 3:56 am    Post subject: Caliper / suspension upgrade Reply with quote
Guys
Great input and solution for 5 lug turbo.
Whats present day cost for these components..?
Also once acquired there is renovation cost
I am guessing $4-5k for calipers, struts and related suspension components
Thanks
Frank
Page 2 of 2
