Posted: Fri Feb 26, 2016 11:59 am Post subject: parts cleaning |
It's not as perfect as blasting and re-zincing, but it sure is a helluva lot easier, quicker, and cheaper! Very pleased with the results. _________________ erstwhile owner of just about every 924 variant ever made |
Power Tryp
Joined: 16 Apr 2009 Posts: 435 Location: Calgary, Alberta
Posted: Fri Feb 26, 2016 12:47 pm Post subject: |
Your method also allows you to keep the sensors and plastics attached where a an abrasive and recoat method would require further teardown. _________________ Melanie - 1980 931
NoName - 1980 931 (seeking rebuild)
Green tartan interior, you don't see that on a Civic. |
Kenodog
Posted: Fri Feb 26, 2016 1:13 pm Post subject: |
Nope. Most definitely would not want to put electrical components in a liquid ultrasonic bath.
Leigh _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
Power Tryp
Posted: Fri Feb 26, 2016 1:14 pm Post subject: |
Why not? _________________ Melanie - 1980 931
Kenodog
Posted: Fri Feb 26, 2016 1:31 pm Post subject: |
What would happen to a radio if you put it in a bathtub full of solvent ? (Not plugged in of course )
1981 931, Sabine
2024 KLX300
2024 KLX140 |
Power Tryp
Posted: Fri Feb 26, 2016 1:39 pm Post subject: |
Depends on how long you had it in there. I assume when it came out and got completely dried off it would be perfectly fine. Much like your cell phone can survive a dunk in the toilet if you get it shut off immediately and open it up to dry out.
But that's an inside item. Automotive electrical sensors are built to handle both extreme temperatures (engine bay) and chemicals (oils, coolants, etc). Obviously I would happily test this if I had a sonic cleaner, alas I do not.
Maybe Dan will oblige us with some science? _________________ Melanie - 1980 931
Kenodog
Posted: Fri Feb 26, 2016 1:51 pm Post subject: |
They are designed to be "resistant" to moisture and oils, not soaked in and the hit with ultrasonic waves. Now they are 30+ years old and the plastic (which was shit even back in the day) is even harder and more brittle, i.e. less likely to seal, than it was back in the age of disco when is was run off the Bosch line in W. Germany.
For the 20 seconds it takes to remove them from the housing I thinks it's time well spent.
1981 931, Sabine
2024 KLX300
2024 KLX140 |
Power Tryp
Posted: Fri Feb 26, 2016 1:54 pm Post subject: |
You've definitely got a point about the shitty plastic. I'd say it's kind of a moot point without testing it and it wasn't really a tech tip, just a general observation made on the whole. _________________ Melanie - 1980 931
Posted: Fri Feb 26, 2016 11:13 pm Post subject: |
The plastics on these items all came out just fine. I am currently doing a batch of cold start valves, and have done this in the past as well. I would not put a circuit board in there, but any of the sensors in the engine bay should be just fine. _________________ erstwhile owner of just about every 924 variant ever made |
agfisher
Joined: 09 May 2007 Posts: 484 Location: West Hartford, CT
agfisher
hdrider19
Joined: 03 May 2016 Posts: 193 Location: Catawissa Missouri(40 mi sw of St Louis)
Posted: Tue Sep 13, 2016 1:01 pm Post subject: |
My choice for cleaning. Whitewall tire cleaner and a garden hose _________________ 87 924S |
agfisher
Posted: Thu Sep 22, 2016 12:25 am Post subject: |
| ideola wrote: | | The plastics on these items all came out just fine. I am currently doing a batch of cold start valves, and have done this in the past as well. I would not put a circuit board in there, but any of the sensors in the engine bay should be just fine. |
What length cycle do you use for this thing using the WD-40 stuff? _________________ 1977 924 N/A Martini Edition |
Noahs944
Joined: 08 Dec 2015 Posts: 782 Location: Calgary, Alberta, Canada
Posted: Thu Sep 22, 2016 1:49 am Post subject: |
This is excellent in a container for about 2 days. Just remember to rinse then dry then lube or paint very shortly after. |
