Knz
Joined: 05 Mar 2014 Posts: 105 Location: Sparrow Bush, NY
Posted: Fri Jan 22, 2016 12:10 pm Post subject: Starting but not Idleing |
I'm currently troubleshooting a start but no idle issue on #196, Its been a while coming but I finally have it all together.
Both fuel pumps are working, the relay is jumpered for now with a fuse. I can get the car to start when flooring the gas pedal / key to start position. It catches and revs up to 2-3k but as soon as I put the key to position 3, the engine dies.
My next line of attach will be to evaluate the WUR override a PO put in and possibly return it to stock.
I wish I had my multi-meter, but its at my apt an hr away, so diagnosis will be limited... I'm wondering if this could be an issue with the starter solenoid.
I will keep this thread updated as I keep troubleshooting, but advice would be surely appreciated. _________________ 1980 931 (#185) for sale
1980 931 (#196) engine rebuild
1983 928S Project
1983 944 Summer Car
2002 BMW 525i Winter Car |
Posted: Fri Jan 22, 2016 1:38 pm Post subject: |
Sounds like an ignition switch failure. _________________ Stefan
Knz
Posted: Fri Jan 22, 2016 1:51 pm Post subject: |
Hmm, I will have to explore that option as well. Are the early 944 ignition switches the same part as ours?
Could I jumper the ignition switch to test the rest of the system?
Edit: To answer my own question, yes 944 ignition switches are interchangeable.
Now just gotta go pull it and try it out. _________________ 1980 931 (#185) for sale
1983 928S Project
1983 944 Summer Car
Posted: Fri Jan 22, 2016 3:25 pm Post subject: |
It's worth a shot as the symptoms sound exactly the same as others have described.
Don't forget jumpering the boost switch too, though that doesn't sound like a possibility in this case, it could help eliminate another variable. _________________ Stefan
Knz
Posted: Sun Jan 24, 2016 11:53 am Post subject: |
Jumpered the ignition switch, The car starts up, and runs, but dies as soon as I take the starter off.
To jumper the boost switch, do I run a positive charge from the battery?
I'm at a loss to what it might be if I'm overriding the ignition switch...
Please help? _________________ 1980 931 (#185) for sale
1983 928S Project
1983 944 Summer Car
Knz
Posted: Sun Jan 24, 2016 2:16 pm Post subject: |
I've been reading that thread. This part doesn't make sense tho:
| Quote: |
Next step will be going back and making sure the fuel pump relay works. Easiest thing to start with is dropping it back in once the car runs, and seeing if it'll restart. If not, check first for a ground on the relay. They ground with a small pin in the top corner; pull the relay board forward enough to see the wire colors, it'll be a small brown wire. This doesn't go to ground!
It (what is it? boost control switch? or is this pin 31 on the fuel pump relay?)grounds and turns the relay on with a switch in the intake duct near the throttle body; this switch kills fuel in case of overboost. Naturally, for safety's sake, they fail in the open position. The switch is easy to test with a multimeter, just see if it's got conductivity between the terminal and it's threads. If it doesn't, you can jumper a wire from that plug to ground, (is this the boost switch jumper???) and see if the fuel pump relay works now - just to check your results. If that was the only problem, the relay should now work and the car should start. The switch is readily available from parts suppliers or the dealership, as it's now superseded to a 993 or 996 Turbo part |
Then 924RACR goes on to talk about tach diagnosis, my tach is working fine, the trouble must be elsewhere... somewhere in the igniton, its cutting out as soon as the starter is off... I'm pouring over haynes right now, we'll see what I come up with...
I'm not even anywhere near ready to drop the fuel pump relay back in... I guess I could try it, but thats just adding another variable to the system. Not to mention I have 3 different fuel pump relays to choose from... One with the fuse up top, another with the 931.615.113.00 part number, and lastly one I picked up from Ideola months ago without the rev limiter... I'll start with that last one. _________________ 1980 931 (#185) for sale
1983 928S Project
1983 944 Summer Car
Knz
Posted: Wed Jan 27, 2016 2:24 pm Post subject: |
Thanks Ideola, that write up was most helpful. Im glad it does not assume the reader knows anything. I've gone down the initial check list, the last item I need to test is the igition control unit...
If I'm interpreting this scematic from haynes correctly... when the starter is engaged the ignition control unit is overriden? And you have current going from #6 to #5 to # 4 to the spark plugs?
Now when the stater goes offline, the current goes from #1 to #2 to #3 to #5 to #4 and then the plugs?
Im thinking I need to test the ignition control unit, I know I'm getting fuel, so I must be losing spark when I take the starter offline... I'll probably not get to testing it until later in the week, if at all before the weekend... _________________ 1980 931 (#185) for sale
1983 928S Project
1983 944 Summer Car
Knz
Posted: Tue Feb 02, 2016 12:54 pm Post subject: |
I finally got a chance to get at the car with a Multi-meter tonight.
I started by resetting the timing. The crank / cam marks were slightly (1-2 teeth on the cam) out of sync. I set it properly and re-tightened the belt
There were no resistors as per the haynes manual to test. Is this something absent on the Turbo?
I proceeded with the haynes procedure to test the the ignition coil. The PO installed an aftermarket coil, and the readings were as follows:
resistance between terminals 15 and 1 - 1.6ohms
Resistance between terminals 1 and 4 - 9.94 Kohms
these seem a bit high to me, but the real problem came next:
I tested the battery voltage - 12.35v
turned the ignition to the on position and proceeded to test the voltage at terminal 15 on the coil.
my first reading was 1.99v, which is much lower than the 5v in the haynes manual. then subsequent readings were around 0.16v
I also jumpered the ignition switch to rule this out as a variable, and I continued to get readings of 0.16v.
Haynes is telling me to check all the wiring for the source of the voltage drop, now I'm not good at doing electrical work, but I'm trying to learn as I go here. Is this where I start checking continuity on all the wires?
Any suggestions?
Should I ditch the aftermarket ignition coil and get a OEM replacement? Are the resistors something that was removed by a PO? _________________ 1980 931 (#185) for sale
1983 928S Project
1983 944 Summer Car
Knz
Posted: Wed Feb 03, 2016 2:22 am Post subject: |
It seems my multimeter may have been giving intermittent fault readings... the display is missing pixels on certain settings, making 6s look like 0s, 9s like 7s and all such fun. I guess thats what I get for using a cheapo harbor freight multimeter...
Borrowing a multimeter from work, and I'll check the voltage at the coil again tonight. _________________ 1980 931 (#185) for sale
1983 928S Project
1983 944 Summer Car
Posted: Wed Feb 03, 2016 1:00 pm Post subject: |
Check fuel pressures and smoke test the intake _________________ Toofah King Bad
Knz
Posted: Wed Feb 03, 2016 1:15 pm Post subject: |
where can I get a Bosch CIS testing kit? the one linked in Ideolas write-up is NLA.
I was using the borrowed multimeter, and confirmed my readings from yesterday. I also tested the voltage at the ICU and the voltage was not sufficient. I guess I'll be learning the wiring diagrams thoroughly in search of the source of the voltage drop. _________________ 1980 931 (#185) for sale
1983 928S Project
1983 944 Summer Car
Knz
Posted: Thu Feb 11, 2016 3:35 am Post subject: |
I should have started with this, but I'm an idiot, so I was looking for bigger problems. The GF and I cleaned up all the grounds last night. The 3 in the trunk were atrocious...
I have the battery on a trickle charger right now, and I'll start testing the all the electrics again, maybe even get to starting her up tonight. More updates to come... _________________ 1980 931 (#185) for sale
1983 928S Project
1983 944 Summer Car
Knz
Posted: Wed Mar 09, 2016 3:53 pm Post subject: |
Issue was resolved. It wasn't the grounds as much as there was no current running through 15 at the fuse box. Thank you MrPink for sorting that out. Now just to sort out the timing, and a few small issues and this car will finally be ready to get on the road again. _________________ 1980 931 (#185) for sale
1983 928S Project
1983 944 Summer Car
