Wareagle32789
Joined: 23 Sep 2015 Posts: 39 Location: Winter Park, FL
Posted: Mon Feb 08, 2016 5:05 am Post subject: Charcoal canister? '80 924 NA |
OK, so I was looking at the large vacuum lines on the driver's side of the engine compartment near the fire wall, and found two of them that went through the fender well. Turns out that they go in and out of a charcoal canister mounted inside the left front wheel well. My local parts guy told me it is some sort of emissions deal, and could be removed.
Two questions:
a. Can I remove this?
b. If I do that , how do I route the vacuum lines if this thing disappears?
Also, Hanyes tells me to look for a vacuum cannister near the right front wheel well, but I can't find anything like that. |
jason c
Posted: Mon Feb 08, 2016 12:21 pm Post subject: Re: Charcoal canister? '80 924 NA |
| Wareagle32789 wrote: | OK, so I was looking at the large vacuum lines on the driver's side of the engine compartment near the fire wall, and found two of them that went through the fender well. Turns out that they go in and out of a charcoal canister mounted inside the left front wheel well. My local parts guy told me it is some sort of emissions deal, and could be removed.
Two questions:
The charcoal canister can be removed without causing a running issue, the row cars don't have it. You may not pass emissions/inspection without it.
Find a vacuum diagram for a row car & follow it to remove all the lines. Don't just plug them, it will affect the gas tank venting
The vacuum canister is a 2-3" tubular black or green plastic tank with one round end and a flat end. It should have 1 vacuum line going to it. |
Posted: Mon Feb 08, 2016 2:38 pm Post subject: |
There's no reason to remove it, and pollution from fuel vapors will far exceed tailpipe emissions if you do. _________________ Toofah King Bad
Fifty50Plus
Joined: 28 Feb 2008 Posts: 1423 Location: Washington DC area
Posted: Tue Feb 09, 2016 7:03 am Post subject: |
road hugging weight _________________ 1979 924 NA race car H-Prod SCCA
1982 924 NA race car - Sold
1981 924 Turbo sold
1982 924 Turbo sold
