Quick question: Size of the throttle body
JjyKs
PostPosted: Wed Feb 03, 2016 10:21 pm    Post subject: Quick question: Size of the throttle body Reply with quote
Managed to get to work earlier today to have some time to buy little necessary things for my car after work.
One thing i was going to get was a silicone tubing between the throttle body (stock), and the ic piping. Forgot to measure it though, and the car is 50 kilometers away.. Does someone have any idea, or possibility to measure how big tube do i need?
PostPosted: Thu Feb 04, 2016 12:52 am    Post subject: Reply with quote
Go to my downloads page: http://garage.ideola.com/top-Downloads.html
Second section under the "More Tools..." heading, there is a link to a spreadsheet with throttle body comparison, should have the data you need.
Dutch924-racer
PostPosted: Thu Feb 04, 2016 5:04 am    Post subject: Reply with quote
80mm
937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
PostPosted: Thu Feb 04, 2016 5:30 am    Post subject: Reply with quote
Dutch924-racer wrote:
80mm
I don't think that's correct...
PostPosted: Thu Feb 04, 2016 5:53 am    Post subject: Reply with quote
I measured 80mm for the rubber flange on an NA throttle body.
JjyKs
PostPosted: Thu Feb 04, 2016 5:57 pm    Post subject: Reply with quote
Seems to be around 80mm. Circumference is around 25cm, resulting in 79.5mm diameter. I had no soft tape measure, so had to measure it with a metal wire and then against metal ruler, so most likely circumference is something like 24.8.
No idea if the local dealer tells the inner or outer diameter of the tube, but they seem to have everything in the stock from 75 to 80, so today i'll go there with the throttlebody
E: If someone is looking at this the 80mm was wrong. It might be tight enough on NA application with a tightened clamp, but it's a lot easier to just stretch a 3"/76mm one to the tb. The correct size would most likely be 77-78mm.
Dutch924-racer
PostPosted: Thu Feb 04, 2016 6:19 pm    Post subject: Reply with quote
I have silicone hoses with 80mm inside fits series 1 oval en series 2 round throttle body.
937 trackday car
Series 2 engine
Fast road camshaft
