Central Locking
FelixP
PostPosted: Tue Dec 29, 2015 5:22 am    Post subject: Central Locking Reply with quote
My 1988 S has central locking which I assume is factory fitted, as I have the big Porsche dongle key fob too.
Lately when locking the car, the passenger side doesn't lock at the same time and now it frequently locks but won't unlock from either side! The key won't turn at all, it feels like it's going to snap against the actuator. Likewise, climbing elegantly through the rear hatch, I can't pull the pins up either from the inside. The only solution is to pull the bonnet release and put the battery leads on/off a couple of times.
I haven't had any luck searching here or online for info on the 924S central locking system and was wondering if anyone else had dealt with it before? I'd happily disable it altogether but if it's just as simple to fix it...
Cheers
1982 924 Turbo with Carrera GT kit, TMIC & DITC
PostPosted: Tue Dec 29, 2015 8:30 am    Post subject: Reply with quote
Did you check Clark's Garage?
jason c
PostPosted: Sat Jan 02, 2016 3:34 pm    Post subject: Re: Central Locking Reply with quote
Cheers
I would start by looking at the relays in the control unit (there is a relay for locking & one for unlocking) and the switches on the locks.
It sounds like the "locking" relay is stuck or one of the switches on the locks is stuck in lock mode.
